AW: [mapserver-users] Postgis Connection Error
Jan Hartmann
jhart at frw.uva.nl
Tue Oct 22 07:25:31 EDT 2002
(I cross-posted this to the PostGIS user's list. Perhaps this discussion
could be continued there)
Düster Horst wrote:
> Hello Jan
> After the first enthusiasm some problems appeared. The main problem
> is, it isn't possible to define two different layers with
> subselections in the same map file. Do you have any experience with
> this phenomenon?? Perhaps it is a bug in the MapServer-Postgis
> interface??
First, I couldn't detect any problem in using more than one PostGIS
layer in a single Mapfile, with or without subselects. Something seems
to be wrong with the definition of one of your layers.
However, there is a potential problem with subselects on non-projected
data (i.e. with SRID = -1).
To test this out I used the following three tables:
continents: the continents with projection latlon (SRID 4326)
continents2: the same, but unprojected (SRID -1)
population: population for 1950, 1975 and 2000
DATA statements:
the_geom from (select oid,* from continents) as foo : OK
the_geom from (select OID,* from continents) as foo : OK
the_geom from (select oid,* from continents2) as foo : OK
the_geom from (select c.oid,c.the_geom, pop.y2000
from continents as c,population as pop
where c.id = pop.id) as foo : OK
the_geom from (select c2.oid,c2.the_geom, pop.y2000
from continents2 as c2,population as pop
where c2.id = pop.id) as foo : OK
where c.id = pop.id) as foo using SRID=4326 : OK
where c2.id = pop.id) as foo using SRID=4326 : Crashes
As you can see:
- oid can be spelled upper- or lowercase
- simple queries work on projected and unprojected maps
- subqueries also work with projected and unprojected maps
as long as you don't specify the SRID explicitly
- unprojected maps can't be used in a subquery which specifies
the SRID
This seems logical to me: it doesn't make sense to try to reproject
non-projected data. Dave Blasby's postings on this subject always
specify "using SRID" and this makes sense to me too, although it doesn't
seem obligatory. Personally I always put my data into some world
projection, even when this is difficult (e.g. hand-digitized field maps,
raster data or CAD/CAM sources).
Hope this helps you further.
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
