[mapserver-users] Announcing 3.6.3 [for Java]
Andrew Collins
andrewrcollins at yahoo.com
Tue Oct 22 17:22:24 EDT 2002
Included below are the three files necessary to create an
implementation of MapScript for Java (on Windows, without
any extra library support--a barebones compilation) with
the most recent version of MapServer (3.6.3).
I used MinGW, MSYS, GnuWin32 and Swig 1.3.15.
MinGW: Minimalist GNU For Windows
http://www.mingw.org/
MSYS
http://www.mingw.org/msys.shtml
GnuWin32
http://gnuwin32.sourceforge.net/
Swig
http://www.swig.org/
The required libraries must be downloaded and unzipped in
the main MapServer distribution directory. You may download
pre-compiled versions from the GnuWin32 project pages:
freetype-2.1.2-1-lib.zip
freetype-2.1.2-bin.zip
gdlib-1.8.4-1-bin.zip
gdlib-1.8.4-lib.zip
libjpeg-6b-bin.zip
libjpeg-6b-lib.zip
libpng-1.2.4-1-bin.zip
libpng-1.2.4-1-lib.zip
libttf-1.4-bin.zip
libttf-1.4-lib.zip
regex-0.12-bin.zip
regex-0.12-lib.zip
xpm-3.4k-1-bin.zip
xpm-3.4k-1-lib.zip
zlib-1.1.4-bin.zip
zlib-1.1.4-lib.zip
The included files go in the mapscript/java directory.
Could these three files be added to the distribution?
I am currently working on a Java-style facade for the
implementation classes generated here.
== Makefile
== mapscript.i
== MapScriptTest.java
== Makefile
#/* File : Makefile */
# SWIG
SWIG=/e/win32app/SWIG-1.3.15/swig
# Java
JAVAC=/e/win32app/j2sdk1.4.1/bin/javac
JAVA=/e/win32app/j2sdk1.4.1/bin/java
JAR=/e/win32app/j2sdk1.4.1/bin/jar
JAVA_INCLUDE=-I/e/win32app/j2sdk1.4.1/include
-I/e/win32app/j2sdk1.4.1/include/win32
# CC
CC=gcc
CCFLAGS=-g -O2 -Wall -Wstrict-prototypes
MAPSCRIPT_FLAGS=-DIGNORE_MISSING_DATA -DUSE_JPEG -DUSE_GD_TTF -DUSE_GD_PNG
-DUSE_GD_JPEG -DUSE_GD_WBMP -DGD_HAS_GDIMAGEGIFPTR
INCLUDES=-I../../ -I../../include/ $(JAVA_INCLUDE)
LDFLAGS=-L../.. -L../../lib -ljpeg_static -ljpeg -ljpeg_static -lttf -lpng -lz
-lfreetype -lm -lregex
all: interface dll java test
interface: mapscript.i
$(SWIG) -I../.. -java -package edu.umn.gis.mapscript.imp mapscript.i
dll: mapscript_wrap.c
$(CC) $(CCFLAGS) $(MAPSCRIPT_FLAGS) $(INCLUDES) -c mapscript_wrap.c
$(CC) $(CCFLAGS) -shared mapscript_wrap.o ../../libmap.a ../../lib/libregex.a
../../lib/libgd.a ../../lib/libXpm.a ../../lib/libfreetype.a
../../lib/libjpeg_static.a ../../bin/libjpeg.dll ../../lib/libjpeg.a
../../lib/libjpeg_static.a ../../bin/libjpeg.dll ../../lib/libpng.a
../../lib/libttf.a ../../lib/libz.a $(LDFLAGS) -Wl,--add-stdcall-alias -o
mapscript_java.dll
java::
$(JAVAC) -d . DBFInfo.java MapScript.java MapScriptJNI.java
SWIGTYPE_p_FILE.java SWIGTYPE_p_gdImagePtr.java SWIGTYPE_p_int.java
SWIGTYPE_p_joinObj.java SWIGTYPE_p_p_char.java SWIGTYPE_p_paletteObj.java
SWIGTYPE_p_void.java classObj.java colorObj.java imageObj.java itemObj.java
labelCacheMemberObj.java labelCacheObj.java labelObj.java layerObj.java
legendObj.java lineObj.java mapObj.java markerCacheMemberObj.java pointObj.java
projectionObj.java queryMapObj.java rectObj.java referenceMapObj.java
resultCacheMemberObj.java resultCacheObj.java scalebarObj.java shapeObj.java
shapefileObj.java styleObj.java webObj.java
$(JAR) cf mapscript_imp.jar edu
test::
$(JAVAC) -classpath mapscript_imp.jar MapScriptTest.java
$(JAVA) -classpath "mapscript_imp.jar;." MapScriptTest
clean:
rm -rf edu mapscript_imp.jar *.class mapscript_wrap.o mapscript.o
mapscript_java.dll mapscript_wrap.c mapscript.java mapscriptJNI.java
DBFInfo.java SWIGTYPE_p_FILE.java SWIGTYPE_p_gdImagePtr.java
SWIGTYPE_p_int.java SWIGTYPE_p_joinObj.java SWIGTYPE_p_p_char.java
SWIGTYPE_p_paletteObj.java SWIGTYPE_p_void.java classObj.java colorObj.java
imageObj.java itemObj.java labelCacheMemberObj.java labelCacheObj.java
labelObj.java layerObj.java legendObj.java lineObj.java mapObj.java
markerCacheMemberObj.java pointObj.java projectionObj.java queryMapObj.java
rectObj.java referenceMapObj.java resultCacheMemberObj.java resultCacheObj.java
scalebarObj.java shapeObj.java shapefileObj.java styleObj.java webObj.java
== mapscript.i
// mapscript.i: SWIG interface file for MapServer scripting extension called
MapScript.
// language specific initialization
#ifdef SWIGTCL8
%module Mapscript
/* static global copy of Tcl interp */
static Tcl_Interp *SWIG_TCL_INTERP;
%init %{
#ifdef USE_TCL_STUBS
if (Tcl_InitStubs(interp, "8.1", 0) == NULL) {
return TCL_ERROR;
/* save Tcl interp pointer to be used in getImageToVar() */
SWIG_TCL_INTERP = interp;
#endif
#endif
// Java specific initialization
#ifdef SWIGJAVA
%module MapScript
#endif
%module mapscript
#include "../../map.h"
#include "../../maptemplate.h"
%include typemaps.i
%include constraints.i
%rename (_class) class;
#ifdef SWIGJAVA
%typemap(javacode) SWIGTYPE %{
public boolean equals(Object obj)
boolean equal = false;
if (obj instanceof $javaclassname)
equal = ((($javaclassname) obj).swigCPtr == this.swigCPtr);
return equal;
#endif
// grab mapserver declarations to wrap
%include "../../mapprimitive.h"
%include "../../mapshape.h"
%include "../../mapproject.h"
%include "../../map.h"
// %include "../../maperror.h"
%apply Pointer NONNULL { mapObj *map };
%apply Pointer NONNULL { layerObj *layer };
#ifdef SWIGPYTHON
// For Python, errors reported via the ms_error structure are translated
// into RuntimeError exceptions. (Chris Chamberlin <cdc at aracnet.com>)
static void _raise_ms_exception(void) {
char errbuf[256];
snprintf(errbuf, 255, "%s: %s %s\n", ms_error.routine,
msGetErrorString(ms_error.code), ms_error.message);
_SWIG_exception(SWIG_RuntimeError, errbuf);
#define raise_ms_exception() { _raise_ms_exception(); return NULL; }
%except {
$function
if ( (ms_error.code != MS_NOERR) && (ms_error.code != -1) )
#endif // SWIGPYTHON
// class extensions for mapObj
%extend mapObj {
mapObj(char *filename) {
mapObj *map;
if(filename && strlen(filename))
return msLoadMap(filename, NULL);
else { /* create an empty map, no layers etc... */
map = (mapObj *)malloc(sizeof(mapObj));
if(!map) {
msSetError(MS_MEMERR, NULL, "msLoadMap()");
return NULL;
initMap(map);
return map;
~mapObj() {
msFreeMap(self);
layerObj *getLayer(int i) {
if(i >= 0 && i < self->numlayers)
return &(self->layers[i]); /* returns an EXISTING layer */
else
return NULL;
layerObj *getLayerByName(char *name) {
int i;
i = msGetLayerIndex(self, name);
if(i != -1)
else
return NULL;
int addColor(int r, int g, int b) {
return msAddColor(self, r, g, b);
int getSymbolByName(char *name) {
return msGetSymbolIndex(&self->symbolset, name);
void prepareQuery() {
int status;
status = msCalculateScale(self->extent, self->units, self->width,
self->height, self->resolution, &self->scale);
if(status != MS_SUCCESS) self->scale = -1; // degenerate extents ok here
imageObj *prepareImage() {
int status;
imageObj *image=NULL;
image = (imageObj *)malloc(sizeof(imageObj));
if(!image) return NULL;
if(self->width == -1 || self->height == -1) {
msSetError(MS_MISCERR, "Image dimensions not specified.",
"prepareImage()");
return NULL;
image->bytes = gdImageCreate(self->width, self->height);
if(!image->bytes) {
msSetError(MS_GDERR, "Unable to initialize image.", "prepareImage()");
return NULL;
image->width = self->width;
image->height = self->height;
image->imagepath = image->imageurl = NULL;
if(msLoadPalette(image->bytes, &(self->palette), self->imagecolor) == -1)
return NULL;
self->cellsize = msAdjustExtent(&(self->extent), self->width,
self->height);
return NULL;
return image;
imageObj *draw() {
image->bytes = msDrawMap(self);
image->width = gdImageSX(image->bytes);
image->height = gdImageSY(image->bytes);
return image;
imageObj *drawQuery() {
image->bytes = msDrawQueryMap(self);
return image;
imageObj *drawLegend() {
image->bytes = msDrawLegend(self);
return image;
imageObj *drawScalebar() {
image->bytes = msDrawScalebar(self);
return image;
imageObj *drawReferenceMap() {
image->bytes = msDrawReferenceMap(self);
return image;
int embedScalebar(imageObj *image) {
return msEmbedScalebar(self, image->bytes);
int embedLegend(imageObj *image) {
return msEmbedLegend(self, image->bytes);
int drawLabelCache(imageObj *image) {
return msDrawLabelCache(image->bytes, self);
int getImageToVar(imageObj *image, char *varname) {
// set a scripting language variable by name with image data
int size = 0;
unsigned char *imgbytes;
// Tcl implementation to define needed variables, initialization
#ifdef SWIGTCL8
Tcl_Obj *imgobj;
int flags = TCL_LEAVE_ERR_MSG;
/* no other initialization needed */
#endif
// Perl implementation to define needed variables, initialization
#ifdef SWIGPERL
#endif
// Python implementation to define needed variables, initialization
#ifdef SWIGPYTHON
#endif
// generic code to get imgbytes, size
switch (self->imagetype) {
case(MS_GIF):
#ifdef USE_GD_GIF
/* GD /w gif doesn't have gdImageGifPtr() */
msSetError(MS_MISCERR, "GIF output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_PNG):
#ifdef USE_GD_PNG
imgbytes = gdImagePngPtr(image->bytes, &size);
#else
msSetError(MS_MISCERR, "PNG output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_JPEG):
#ifdef USE_GD_JPEG
imgbytes = gdImageJpegPtr(image->bytes, &size, self->imagequality);
#else
msSetError(MS_MISCERR, "JPEG output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_WBMP):
#ifdef USE_GD_WBMP
imgbytes = gdImageWBMPPtr(image->bytes, &size, 1);
#else
msSetError(MS_MISCERR, "WBMP output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
default:
msSetError(MS_MISCERR, "Unknown output image type.",
"getImageToVar()");
return(MS_FAILURE);
// Tcl implementation to set variable
#ifdef SWIGTCL8
imgobj = Tcl_NewByteArrayObj(imgbytes, size);
Tcl_IncrRefCount(imgobj);
Tcl_SetVar2Ex(SWIG_TCL_INTERP, varname, (char *)NULL, imgobj, flags);
Tcl_DecrRefCount(imgobj);
gdFree(imgbytes);
return MS_SUCCESS;
#endif
// Perl implementation to set variable
#ifdef SWIGPERL
#endif
// Python implementation to set variable
#ifdef SWIGPYTHON
#endif
// return failure for unsupported swig languages
msSetError(MS_MISCERR, "Unsupported scripting language.",
"getImageToVar()");
return MS_FAILURE;
labelCacheMemberObj *nextLabel() {
static int i=0;
if(i<self->labelcache.numlabels)
return &(self->labelcache.labels[i++]);
else
return NULL;
int queryByPoint(pointObj *point, int mode, double buffer) {
return msQueryByPoint(self, -1, mode, *point, buffer);
int queryByRect(rectObj rect) {
return msQueryByRect(self, -1, rect);
int queryByFeatures(int slayer) {
return msQueryByFeatures(self, -1, slayer);
int queryByShape(shapeObj *shape) {
return msQueryByShape(self, -1, shape);
//int setWKTProjection(char *string) {
// return msLoadWKTProjectionString(string, &(self->projection));
%new char *getProjection() {
return msGetProjectionString(&(self->projection));
int setProjection(char *string) {
return msLoadProjectionString(&(self->projection), string);
int save(char *filename) {
return msSaveMap(self, filename);
int saveQuery(char *filename) {
return msSaveQuery(self, filename);
int saveQueryAsGML(char *filename) {
return msGMLWriteQuery(self, filename);
char *getMetaData(char *name) {
return(msLookupHashTable(self->web.metadata, name));
int setMetaData(char *name, char *value) {
if (!self->web.metadata)
self->web.metadata = msCreateHashTable();
if (msInsertHashTable(self->web.metadata, name, value) == NULL)
return MS_FAILURE;
return MS_SUCCESS;
int setSymbolSet(char *szFileName)
msFreeSymbolSet(&self->symbolset);
msInitSymbolSet(&self->symbolset);
// Set symbolset filename
self->symbolset.filename = strdup(szFileName);
// Symbolset shares same fontset as main mapfile
self->symbolset.fontset = &(self->fontset);
return msLoadSymbolSet(&self->symbolset);
int mapObj_getNumSymbols()
return self->symbolset.numsymbols;
int setFontSet(char *szFileName)
msFreeFontSet(&(self->fontset));
msInitFontSet(&(self->fontset));
// Set fontset filename
self->fontset.filename = strdup(szFileName);
return msLoadFontSet(&(self->fontset));
int moveLayerup(int layerindex) {
return msMoveLayerUp(self, layerindex);
int moveLayerdown(int layerindex) {
return msMoveLayerDown(self, layerindex);
int *getLayersdrawingOrder() {
return self->layerorder;
int setLayersdrawingOrder(int *panIndexes) {
return msSetLayersdrawingOrder(self, panIndexes);
char *processTemplate(int bGenerateImages, char **names, char **values, int
numentries) {
return msProcessTemplate(self, bGenerateImages, names, values,
numentries);
char *processLegendTemplate(char **names, char **values, int numentries) {
return msProcessLegendTemplate(self, names, values, numentries);
char *processQueryTemplate(char **names, char **values, int numentries) {
return msProcessQueryTemplate(self, names, values, numentries);
// class extensions for layerObj, always within the context of a map
%extend layerObj {
layerObj(mapObj *map) {
if(map->numlayers == MS_MAXLAYERS) // no room
return(NULL);
if(initLayer(&(map->layers[map->numlayers])) == -1)
return(NULL);
map->layers[map->numlayers].index = map->numlayers;
map->layerorder[map->numlayers] = map->numlayers;
map->numlayers++;
return &(map->layers[map->numlayers-1]);
~layerObj() {
return; // map deconstructor takes care of it
int open(char *path) {
int status;
status = msLayerOpen(self, path);
if (status == MS_SUCCESS) {
return msLayerGetItems(self);
return status;
void close() {
msLayerClose(self);
int getShape(shapeObj *shape, int tileindex, int shapeindex) {
return msLayerGetShape(self, shape, tileindex, shapeindex);
resultCacheMemberObj *getResult(int i) {
if(!self->resultcache) return NULL;
if(i >= 0 && i < self->resultcache->numresults)
return &self->resultcache->results[i];
else
return NULL;
classObj *getClass(int i) { // returns an EXISTING class
if(i >= 0 && i < self->numclasses)
return &(self->class[i]);
else
return NULL;
char *getItem(int i) { // returns an EXISTING item
if(i >= 0 && i < self->numitems)
return (self->items[i]);
else
return NULL;
int draw(mapObj *map, imageObj *image) {
return msDrawLayer(map, self, image->bytes);
int drawQuery(mapObj *map, imageObj *image) {
int queryByAttributes(mapObj *map, int mode) {
return msQueryByAttributes(map, self->index, mode);
int queryByPoint(mapObj *map, pointObj *point, int mode, double buffer) {
return msQueryByPoint(map, self->index, mode, *point, buffer);
int queryByRect(mapObj *map, rectObj rect) {
return msQueryByRect(map, self->index, rect);
int queryByFeatures(mapObj *map, int slayer) {
return msQueryByFeatures(map, self->index, slayer);
int queryByShape(mapObj *map, shapeObj *shape) {
return msQueryByShape(map, self->index, shape);
int setFilter(char *string) {
return loadExpressionString(&self->filter, string);
int addFeature(shapeObj *shape) {
self->connectiontype = MS_INLINE; // set explicitly
if(insertFeatureList(&(self->features), shape) == NULL)
return -1;
else
return 0;
return(msLookupHashTable(self->metadata, name));
if (!self->metadata)
self->metadata = msCreateHashTable();
if (msInsertHashTable(self->metadata, name, value) == NULL)
return MS_FAILURE;
return MS_SUCCESS;
// No longer a memory leak, at least with swig 1.3.11. Swig makes a copy
// of the returned string and then free's it.
%new char *getWMSFeatureInfoURL(mapObj *map, int click_x, int click_y, int
feature_count, char *info_format) {
return(msWMSGetFeatureInfoURL(map, self, click_x, click_y, feature_count,
info_format));
// class extensions for classObj, always within the context of a layer
%extend classObj {
classObj(layerObj *layer) {
if(layer->numclasses == MS_MAXCLASSES) // no room
return NULL;
if(initClass(&(layer->class[layer->numclasses])) == -1)
return NULL;
layer->class[layer->numclasses].type = layer->type;
layer->numclasses++;
return &(layer->class[layer->numclasses-1]);
~classObj() {
return; // do nothing, map deconstrutor takes care of it all
int setExpression(char *string) {
return loadExpressionString(&self->expression, string);
int setText(layerObj *layer, char *string) {
return loadExpressionString(&self->text, string);
return MS_FAILURE;
return MS_SUCCESS;
int drawLegendIcon(mapObj *map, layerObj *layer, int width, int height,
imageObj *dstImage, int dstX, int dstY) {
return msDrawLegendIcon(map, layer, self, width, height, dstImage->bytes,
dstX, dstY);
imageObj *createLegendIcon(mapObj *map, layerObj *layer, int width, int
height) {
image->bytes = msCreateLegendIcon(map, layer, self, width, height);
return image;
// class extensions for pointObj, useful many places
%extend pointObj {
pointObj() {
return (pointObj *)malloc(sizeof(pointObj));
~pointObj() {
free(self);
int project(projectionObj *in, projectionObj *out) {
return msProjectPoint(in, out, self);
int draw(mapObj *map, layerObj *layer, imageObj *image, int classindex, char
*text) {
return msDrawPoint(map, layer, self, image->bytes, classindex, text);
double distanceToPoint(pointObj *point) {
return msDistanceBetweenPoints(self, point);
double distanceToLine(pointObj *a, pointObj *b) {
return msDistanceFromPointToLine(self, a, b);
double distanceToShape(shapeObj *shape) {
switch(shape->type) {
case(MS_SHAPE_POINT):
return msDistanceFromPointToMultipoint(self, &(shape->line[0]));
case(MS_SHAPE_LINE):
return msDistanceFromPointToPolyline(self, shape);
case(MS_SHAPE_POLYGON):
return msDistanceFromPointToPolygon(self, shape);
return -1;
// class extensions for lineObj (eg. a line or group of points), useful many
places
%extend lineObj {
lineObj() {
lineObj *line;
line = (lineObj *)malloc(sizeof(lineObj));
if(!line)
return(NULL);
line->numpoints=0;
line->point=NULL;
return line;
~lineObj() {
free(self->point);
free(self);
return msProjectLine(in, out, self);
pointObj *get(int i) {
if(i<0 || i>=self->numpoints)
return NULL;
else
return &(self->point[i]);
int add(pointObj *p) {
if(self->numpoints == 0) { /* new */
self->point = (pointObj *)malloc(sizeof(pointObj));
if(!self->point)
return -1;
} else { /* extend array */
self->point = (pointObj *)realloc(self->point,
sizeof(pointObj)*(self->numpoints+1));
if(!self->point)
return -1;
self->point[self->numpoints].x = p->x;
self->point[self->numpoints].y = p->y;
self->numpoints++;
return 0;
// class extensions for shapeObj
%extend shapeObj {
shapeObj(int type) {
shapeObj *shape;
shape = (shapeObj *)malloc(sizeof(shapeObj));
if(!shape)
return NULL;
msInitShape(shape);
if(type >= 0) shape->type = type;
return shape;
~shapeObj() {
msFreeShape(self);
free(self);
return msProjectShape(in, out, self);
lineObj *get(int i) {
if(i<0 || i>=self->numlines)
return NULL;
else
return &(self->line[i]);
int add(lineObj *line) {
return msAddLine(self, line);
int draw(mapObj *map, layerObj *layer, imageObj *image) {
return msDrawShape(map, layer, self, image->bytes, MS_TRUE);
void setBounds() {
int i, j;
self->bounds.minx = self->bounds.maxx = self->line[0].point[0].x;
self->bounds.miny = self->bounds.maxy = self->line[0].point[0].y;
for( i=0; i<self->numlines; i++ ) {
for( j=0; j<self->line[i].numpoints; j++ ) {
self->bounds.minx = MS_MIN(self->bounds.minx, self->line[i].point[j].x);
self->bounds.maxx = MS_MAX(self->bounds.maxx, self->line[i].point[j].x);
self->bounds.miny = MS_MIN(self->bounds.miny, self->line[i].point[j].y);
self->bounds.maxy = MS_MAX(self->bounds.maxy, self->line[i].point[j].y);
return;
int copy(shapeObj *dest) {
return(msCopyShape(self, dest));
char *getValue(int i) { // returns an EXISTING value
if(i >= 0 && i < self->numvalues)
return (self->values[i]);
else
return NULL;
int contains(pointObj *point) {
if(self->type == MS_SHAPE_POLYGON)
return msIntersectPointPolygon(point, self);
return -1;
int intersects(shapeObj *shape) {
switch(self->type) {
return msIntersectPolylines(self, shape);
return msIntersectPolylinePolygon(self, shape);
break;
return msIntersectPolylinePolygon(shape, self);
return msIntersectPolygons(self, shape);
break;
return -1;
// class extensions for rectObj
%extend rectObj {
rectObj() {
rectObj *rect;
rect = (rectObj *)calloc(1, sizeof(rectObj));
if(!rect)
return(NULL);
return(rect);
~rectObj() {
free(self);
return msProjectRect(in, out, self);
double fit(int width, int height) {
return msAdjustExtent(self, width, height);
*text) {
shapeObj shape;
msInitShape(&shape);
msRectToPolygon(*self, &shape);
shape.classindex = classindex;
shape.text = strdup(text);
msDrawShape(map, layer, &shape, image->bytes, MS_TRUE);
msFreeShape(&shape);
return 0;
// class extensions for shapefileObj
%extend shapefileObj {
shapefileObj(char *filename, int type) {
shapefileObj *shapefile;
int status;
shapefile = (shapefileObj *)malloc(sizeof(shapefileObj));
if(!shapefile)
return NULL;
if(type == -1)
status = msSHPOpenFile(shapefile, "rb", NULL, filename);
else if(type == -2)
status = msSHPOpenFile(shapefile, "rb+", NULL, filename);
else
status = msSHPCreateFile(shapefile, filename, type);
if(status == -1) {
msSHPCloseFile(shapefile);
free(shapefile);
return NULL;
return(shapefile);
~shapefileObj() {
msSHPCloseFile(self);
free(self);
int get(int i, shapeObj *shape) {
if(i<0 || i>=self->numshapes)
return -1;
msFreeShape(shape); /* frees all lines and points before re-filling */
msSHPReadShape(self->hSHP, i, shape);
return 0;
int getPoint(int i, pointObj *point) {
return -1;
msSHPReadPoint(self->hSHP, i, point);
return 0;
int getTransformed(mapObj *map, int i, shapeObj *shape) {
return -1;
msTransformShape(shape, map->extent, map->cellsize);
return 0;
void getExtent(int i, rectObj *rect) {
msSHPReadBounds(self->hSHP, i, rect);
int add(shapeObj *shape) {
return msSHPWriteShape(self->hSHP, shape);
int addPoint(pointObj *point) {
return msSHPWritePoint(self->hSHP, point);
// class extensions for imageObj
%extend imageObj {
imageObj(int width, int height) {
image->bytes = gdImageCreate(width, height);
image->width = width;
image->height = height;
return(image);
~imageObj() {
gdImageDestroy(self->bytes);
free(self->imagepath);
free(self->imageurl);
free(self);
void free() {
free(self);
void saveImage(char *filename, int type, int transparent, int interlace, int
quality) {
msSaveImage(self->bytes, filename, type, transparent, interlace, quality);
// class extensions for projectionObj
%extend projectionObj {
projectionObj(char *string) {
int status;
projectionObj *proj=NULL;
proj = (projectionObj *)malloc(sizeof(projectionObj));
if(!proj) return NULL;
msInitProjection(proj);
status = msLoadProjectionString(proj, string);
if(status == -1) {
msFreeProjection(proj);
free(proj);
return NULL;
return proj;
~projectionObj() {
msFreeProjection(self);
free(self);
// class extensions for labelCacheObj - TP mods
%extend labelCacheObj {
void freeCache() {
int i;
for (i = 0; i < self->numlabels; i++) {
free(self->labels[i].string);
msFreeShape(self->labels[i].poly);
self->numlabels = 0;
for (i = 0; i < self->nummarkers; i++) {
msFreeShape(self->markers[i].poly);
self->nummarkers = 0;
// class extensions for DBFInfo - TP mods
%extend DBFInfo {
char *getFieldName(int iField) {
static char pszFieldName[1000];
int pnWidth;
int pnDecimals;
msDBFGetFieldInfo(self, iField, &pszFieldName[0], &pnWidth, &pnDecimals);
return pszFieldName;
int getFieldWidth(int iField) {
int pnWidth;
int pnDecimals;
return pnWidth;
int getFieldDecimals(int iField) {
int pnWidth;
int pnDecimals;
return pnDecimals;
int getFieldType(int iField) {
return msDBFGetFieldInfo(self, iField, NULL, NULL, NULL);
/* File : main.java */
import edu.umn.gis.mapscript.imp.*;
public class MapScriptTest
static
try
System.loadLibrary("mapscript_java");
catch (UnsatisfiedLinkError e)
System.err.println("Native code library failed to load.\n");
System.exit(1);
public static void main(String argv[])
System.out.println("MapScript.MS_SHAPEFILE_POINT=[" +
MapScript.MS_SHAPEFILE_POINT + "]");
System.out.println("MapScript.MS_SHAPEFILE_ARC=[" +
MapScript.MS_SHAPEFILE_ARC + "]");
System.out.println("MapScript.MS_SHAPEFILE_POLYGON=[" +
MapScript.MS_SHAPEFILE_POLYGON + "]");
System.out.println("MapScript.MS_SHAPEFILE_MULTIPOINT=[" +
MapScript.MS_SHAPEFILE_MULTIPOINT + "]");
System.out.println("MapScript.MS_SHP_POINTM=[" + MapScript.MS_SHP_POINTM +
System.out.println("MapScript.MS_SHP_ARCM=[" + MapScript.MS_SHP_ARCM +
System.out.println("MapScript.MS_SHP_POLYGONM=[" +
MapScript.MS_SHP_POLYGONM + "]");
System.out.println("MapScript.MS_SHP_MULTIPOINTM=[" +
MapScript.MS_SHP_MULTIPOINTM + "]");
System.out.println("MapScript.FTString=[" + MapScript.FTString + "]");
System.out.println("MapScript.FTInteger=[" + MapScript.FTInteger + "]");
System.out.println("MapScript.FTDouble=[" + MapScript.FTDouble + "]");
System.out.println("MapScript.FTInvalid=[" + MapScript.FTInvalid + "]");
System.out.println("MapScript.MS_VERSION=[" + MapScript.MS_VERSION + "]");
System.out.println("MapScript.MS_TRUE=[" + MapScript.MS_TRUE + "]");
System.out.println("MapScript.MS_FALSE=[" + MapScript.MS_FALSE + "]");
System.out.println("MapScript.MS_ON=[" + MapScript.MS_ON + "]");
System.out.println("MapScript.MS_OFF=[" + MapScript.MS_OFF + "]");
System.out.println("MapScript.MS_DEFAULT=[" + MapScript.MS_DEFAULT + "]");
System.out.println("MapScript.MS_EMBED=[" + MapScript.MS_EMBED + "]");
System.out.println("MapScript.MS_DELETE=[" + MapScript.MS_DELETE + "]");
System.out.println("MapScript.MS_YES=[" + MapScript.MS_YES + "]");
System.out.println("MapScript.MS_NO=[" + MapScript.MS_NO + "]");
System.out.println("MapScript.MS_SINGLE=[" + MapScript.MS_SINGLE + "]");
System.out.println("MapScript.MS_MULTIPLE=[" + MapScript.MS_MULTIPLE +
System.out.println("MapScript.MS_FILE_MAP=[" + MapScript.MS_FILE_MAP +
System.out.println("MapScript.MS_FILE_SYMBOL=[" + MapScript.MS_FILE_SYMBOL
System.out.println("MapScript.MS_INCHES=[" + MapScript.MS_INCHES + "]");
System.out.println("MapScript.MS_FEET=[" + MapScript.MS_FEET + "]");
System.out.println("MapScript.MS_MILES=[" + MapScript.MS_MILES + "]");
System.out.println("MapScript.MS_METERS=[" + MapScript.MS_METERS + "]");
System.out.println("MapScript.MS_KILOMETERS=[" + MapScript.MS_KILOMETERS +
System.out.println("MapScript.MS_DD=[" + MapScript.MS_DD + "]");
System.out.println("MapScript.MS_PIXELS=[" + MapScript.MS_PIXELS + "]");
System.out.println("MapScript.MS_SHAPE_POINT=[" + MapScript.MS_SHAPE_POINT
System.out.println("MapScript.MS_SHAPE_LINE=[" + MapScript.MS_SHAPE_LINE +
System.out.println("MapScript.MS_SHAPE_POLYGON=[" +
MapScript.MS_SHAPE_POLYGON + "]");
System.out.println("MapScript.MS_SHAPE_NULL=[" + MapScript.MS_SHAPE_NULL +
System.out.println("MapScript.MS_LAYER_POINT=[" + MapScript.MS_LAYER_POINT
System.out.println("MapScript.MS_LAYER_LINE=[" + MapScript.MS_LAYER_LINE +
System.out.println("MapScript.MS_LAYER_POLYGON=[" +
MapScript.MS_LAYER_POLYGON + "]");
System.out.println("MapScript.MS_LAYER_RASTER=[" +
MapScript.MS_LAYER_RASTER + "]");
System.out.println("MapScript.MS_LAYER_ANNOTATION=[" +
MapScript.MS_LAYER_ANNOTATION + "]");
System.out.println("MapScript.MS_LAYER_QUERY=[" + MapScript.MS_LAYER_QUERY
System.out.println("MapScript.MS_LAYER_CIRCLE=[" +
MapScript.MS_LAYER_CIRCLE + "]");
System.out.println("MapScript.MS_TRUETYPE=[" + MapScript.MS_TRUETYPE +
System.out.println("MapScript.MS_BITMAP=[" + MapScript.MS_BITMAP + "]");
System.out.println("MapScript.MS_UL=[" + MapScript.MS_UL + "]");
System.out.println("MapScript.MS_LR=[" + MapScript.MS_LR + "]");
System.out.println("MapScript.MS_UR=[" + MapScript.MS_UR + "]");
System.out.println("MapScript.MS_LL=[" + MapScript.MS_LL + "]");
System.out.println("MapScript.MS_CR=[" + MapScript.MS_CR + "]");
System.out.println("MapScript.MS_CL=[" + MapScript.MS_CL + "]");
System.out.println("MapScript.MS_UC=[" + MapScript.MS_UC + "]");
System.out.println("MapScript.MS_LC=[" + MapScript.MS_LC + "]");
System.out.println("MapScript.MS_CC=[" + MapScript.MS_CC + "]");
System.out.println("MapScript.MS_AUTO=[" + MapScript.MS_AUTO + "]");
System.out.println("MapScript.MS_XY=[" + MapScript.MS_XY + "]");
System.out.println("MapScript.MS_TINY=[" + MapScript.MS_TINY + "]");
System.out.println("MapScript.MS_SMALL=[" + MapScript.MS_SMALL + "]");
System.out.println("MapScript.MS_MEDIUM=[" + MapScript.MS_MEDIUM + "]");
System.out.println("MapScript.MS_LARGE=[" + MapScript.MS_LARGE + "]");
System.out.println("MapScript.MS_GIANT=[" + MapScript.MS_GIANT + "]");
System.out.println("MapScript.MS_NORMAL=[" + MapScript.MS_NORMAL + "]");
System.out.println("MapScript.MS_HILITE=[" + MapScript.MS_HILITE + "]");
System.out.println("MapScript.MS_SELECTED=[" + MapScript.MS_SELECTED +
System.out.println("MapScript.MS_INLINE=[" + MapScript.MS_INLINE + "]");
System.out.println("MapScript.MS_SHAPEFILE=[" + MapScript.MS_SHAPEFILE +
System.out.println("MapScript.MS_TILED_SHAPEFILE=[" +
MapScript.MS_TILED_SHAPEFILE + "]");
System.out.println("MapScript.MS_SDE=[" + MapScript.MS_SDE + "]");
System.out.println("MapScript.MS_OGR=[" + MapScript.MS_OGR + "]");
System.out.println("MapScript.MS_UNUSED_1=[" + MapScript.MS_UNUSED_1 +
System.out.println("MapScript.MS_POSTGIS=[" + MapScript.MS_POSTGIS + "]");
System.out.println("MapScript.MS_WMS=[" + MapScript.MS_WMS + "]");
System.out.println("MapScript.MS_ORACLESPATIAL=[" +
MapScript.MS_ORACLESPATIAL + "]");
System.out.println("MapScript.MS_GIF=[" + MapScript.MS_GIF + "]");
System.out.println("MapScript.MS_PNG=[" + MapScript.MS_PNG + "]");
System.out.println("MapScript.MS_JPEG=[" + MapScript.MS_JPEG + "]");
System.out.println("MapScript.MS_WBMP=[" + MapScript.MS_WBMP + "]");
System.out.println("MapScript.MS_GML=[" + MapScript.MS_GML + "]");
System.out.println("MapScript.MS_CJC_NONE=[" + MapScript.MS_CJC_NONE +
System.out.println("MapScript.MS_CJC_BEVEL=[" + MapScript.MS_CJC_BEVEL +
System.out.println("MapScript.MS_CJC_BUTT=[" + MapScript.MS_CJC_BUTT +
System.out.println("MapScript.MS_CJC_MITER=[" + MapScript.MS_CJC_MITER +
System.out.println("MapScript.MS_CJC_ROUND=[" + MapScript.MS_CJC_ROUND +
System.out.println("MapScript.MS_CJC_SQUARE=[" + MapScript.MS_CJC_SQUARE +
System.out.println("MapScript.MS_CJC_TRIANGLE=[" +
MapScript.MS_CJC_TRIANGLE + "]");
System.out.println("MapScript.MS_SUCCESS=[" + MapScript.MS_SUCCESS + "]");
System.out.println("MapScript.MS_FAILURE=[" + MapScript.MS_FAILURE + "]");
System.out.println("MapScript.MS_DONE=[" + MapScript.MS_DONE + "]");
Andrew Collins - andrewrcollins at yahoo.com
http://profiles.yahoo.com/andrewrcollins/
__________________________________________________
Do you Yahoo!?
Y! Web Hosting - Let the expert host your web site
http://webhosting.yahoo.com/
