Fw: [mapserver-users] How to query the non geometry data in POSTGIS?
Brent Fraser
bfraser at geoanalytic.com
Wed Oct 23 14:22:28 EDT 2002
Well, I should read the MapServer doc before making requests.
There alreadly exists a CGI mechanism for changing a map file variable from
a web page. See the bottom of:
http://mapserver.gis.umn.edu/doc36/cgi-reference.html
This will solve my problem of allow end-user queries on-the-fly; I'll have
some JavaScript create a new DATA string with a where-clause based on user
specified attribute values.
Brent Fraser
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>; <yeong888 at giga.net.tw>
Sent: Wednesday, October 23, 2002 11:23 AM
Subject: Re: [mapserver-users] How to query the non geometry data in
POSTGIS?
> It depends on your requirement.
> 1. If you want to allow end-user queries of non-geometric tables stored
in
> POSTGIS (which means they're just plain old PostgreSQL tables), then
> MapServer or MapScript can't do it (at least not that I know of). Use
> server-side scripting such as Perl, PHP, etc.
> 2. If you want to simply put a restriction on the geometric data returned
> based on attibute values, add a where-clause to the layer's DATA
definition
> in the map file. This can get fairly sophisticated in MapServer 3.7 as
you
> can use sub-SELECT statements to perform joins between the geometric table
> and other non-geometric tables. Here's a snippet from David Blasby's
> message of Sept 30:
> DATA "the_geom from (SELECT the_geom, nut3.nurgcd as nurgcd,
un3rt.unit
> as
> unit,gid FROM nut3) as foo using unique gid using SRID=6543"
> 3. If you want to allow end-user queries of geometric tables based on
> attribute values, I think the answer is MapScript. I would like to find
out
> how to do it using just the CGI interface, but I think it is beyond
> MapServer's capabilies.
> How about enhancing MapServer to allow the passing of a where-clause for
a
> layer via http?
> Brent Fraser
> From: <yeong888 at giga.net.tw>
> Sent: Wednesday, October 23, 2002 7:26 AM
> Subject: [mapserver-users] How to query the non geometry data in POSTGIS?
> > Dear all:
> > I am sorry to bother everyone. I have been tried the MapServer+PostGIS
> > many times, but I can't find the soultion to resolve question following:
> > How to query the non geometry data in PostGIS+PostgreSQL?
> > Is there anyone can tell how to handle this problem?
> > Thank you
