[mapserver-users] mouse over map (FWD)
Steve Lime
steve.lime at dnr.state.mn.us
Fri Oct 25 13:33:19 EDT 2002
Hi Thomas: I've attached a simpler version of this stuff that was used
to actually do the weather version. In this case a perl script is used
to build XML files that are then read by an XML enabled version of the
mapplet. The XML files boil down to something like an image map and the
applet interprets that image map for mouse overs...
You can see this application in action at
http://thoreau.dnr.state.mn.us/cgi-bin/mapdoqs.pl. You have to zoom
in a bit to see the DOQs and then look for little red dots to mouse
over. That data is from the USGS GNIS database.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Thomas, Cord" <cthomas at rand.org> 10/23/02 06:00PM >>>
Is source available for this maplet? Does dnr publish its source?
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Wednesday, October 23, 2002 3:38 PM
To: gabriel at ciasc.gov.br; mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] mouse over map (FWD)
Oops. It should be http://thoreau.dnr.state.mn.us/weather/map.html
Steve
>>> "gabriel" <gabriel at ciasc.gov.br> 10/23/02 03:07PM >>>
This was a good example on weather use of MS.
Today, I could not find this URL. Anyone could help me.
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Cc: <Amy.Stender at erdc.usace.army.mil>
Sent: Friday, February 01, 2002 2:51 PM
Subject: [mapserver-users] mouse over map (FWD)
> ------------- Begin Forwarded Message -------------
> From: "Stender, Amy ERDC-CRREL-NH" <Amy.Stender at erdc.usace.army.mil>
> To: mapserver-info at lists.gis.umn.edu
> Subject: mouse over map
> Date: Fri, 1 Feb 2002 10:15:35 -0500
> MIME-Version: 1.0
> I was looking at the DNR weather map:
> http://www.dnr.state.mn.us/weather/map.html
> and I was wondering if anyone could help me try something like that
for my
> map. I'd like the user to be able to mouse over a point and have an
> "alt"-like box appear next to the mouse. But my map isn't static, so
I can
> necessarily say: when mouse is that this pixel by this pixel, popUp.
> Is this something I'll have to alter in the mapplet?
> Thanks in advance,
> Amy
> Amy L. Stender
> Remote Sensing/GIS Center
> Cold Regions Research and Engineering Laboratory
> United States Army Corps of Engineers
> 72 Lyme Road, Hanover, NH 03755-1290
> Tel: (603) 646-4733
> Fax: (603) 646-4730
> astender at crrel.usace.army.mil
> ------------- End Forwarded Message -------------
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021025/177a26cb/mapdoqs.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20021025/177a26cb/mapplet_xml.obj
