[mapserver-users] GDAL compilation error
Sandor Csaba
c.sandor at emla.hu
Tue Oct 29 05:31:17 EST 2002
The second option is true, I did not "install" gdal. I gave configure
--with-gdal=/home/emla/lib/gdal/apps/gdal-config
After this configure runs ok, but when I try to make it it says at target
shp2img:
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_JPEG
-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DUSE_GDAL -I/home/emla/lib/gd -I/home/emla/lib/jpeg
-I/home/emla/lib/gdal/port -I/home/emla/lib/gdal/core
-I/home/emla/lib/gdal/ogr
-I/home/emla/lib/gdal/ogr/ogrsf_frmts shp2img.o -L. -lmap
-L/home/emla/lib/gd -lgd -L/home/emla/lib/jpeg -ljpeg
-L/home/emla/lib/freetype1/lib/.libs -lttf -L/home/emla/lib/libpng -lpng
-L/home/emla/lib/zlib -lz -L/home/emla/lib/jpeg -ljpeg
-ljpeg /home/emla/lib/gdal/ogr/ogrsf_frmts/ogrsf_frmts.a
/home/emla/lib/gdal/gdal.a /home/emla/lib/gdal/ogr/ogr.a
/home/emla/lib/gdal/gdal.a /home/emla/lib/gdal/port/cpl.a -lz -lm -ldl
-L/usr/local/lib -lm -lm -o shp2img
*** Error code 1
make: Fatal error: Command failed for target `shp2img'
I suspect this is the first executable it tries to build...
Csaba
>Sandor,
>It is trying to execute the path you gave as if it were the gdal-config
>script. Is /home/emla/lib/gdal a build directory, or an install directory?
>If you installed GDAL you should be able to find a bin/gdal-config script
>in the install tree. Use that as the argument to --with-gdal. If you didn't
>install GDAL then give /home/emla/lib/gdal/apps/gdal-config as the argument
>to the --with-gdal option.
>Good luck,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
{Kornyezeti Management es Jog Egyesulet
{Environmental Management and Law Association
{www.emla.hu
{1076 Budapest
{Garay u. 29-31
{Hungary
{Tel/fax: 36-1-3228462, 36-1-3529925
{Mobil: 06-20-949-1447
