[mapserver-users] Defining Classes/Labels for contours
Puneet Kishor
pkishor at GeoAnalytics.com
Wed Oct 30 18:03:45 EST 2002
there is no mechanism for creating graduated colors for a feature based on
class ranges. What you have done is correct.
If you don't want the legends to be created, just take out the NAME line
from within the CLASS definitions.
Hth.
Pk/
-----Original Message-----
From: Michael Soracco [mailto:Michael.Soracco at noaa.gov]
Sent: Wednesday, October 30, 2002 2:17 PM
To: mapserver
Subject: [mapserver-users] Defining Classes/Labels for contours
I've checked the archives and didn't see anything on what I need to do.
It's probably straightforward, but I haven't been able to figure it out...
I have a Polyline shapefile where each polyline has a classified value (i.e.
Contour 1,2,3,4,5,6,7,8,9,10). I've tried the following to draw the
contours in different colors but have only succeeded in creating a Legend
Class for each level. Is it possible to have graduated colors for the lines
within the same Layer Object?
LAYER
NAME BATHY
TYPE LINE
STATUS OFF
DATA bathy
CLASSITEM "Contour"
MAXSCALE 500000
CLASS
NAME "0 - 5"
EXPRESSION "(Contour >= 0 AND Contour <=5)"
COLOR 200 0 0
END
CLASS
NAME "5 - 10"
EXPRESSION "(Contour > 5 AND Contour <=10)"
COLOR 0 200 0
END
END
Thanks in advance for the help.
Michael Soracco
SES, Inc. for NOAA/NESDIS
at NOAA Science Center (WWB)
5200 Auth Road, Room 607
Camp Springs, MD 20746
Voice: 301.763.8142 x117
FAX: 301.763.8131
