[mapserver-users] PHP/MapScript compile and install on RedHat 7.x
Thomas P. Colson
tpcolson at nexussoft.com
Thu Oct 31 10:56:40 EST 2002
Thanks for the link!
Unfortunatly, I went ahead and did a fresh install of 7.3 before I read it...and got to the part about the manual php install.
Finally managed to get the demo working, sans gif, using png instead.
So....do I just re-install PHP, (Version 4.1.2 came with 7.3) or what levers do I need to pull to make mapscript work?
Thanks.
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Wednesday, October 30, 2002 5:04 PM
To: Thomas P. Colson
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] PHP/MapScript compile and install on
RedHat 7.x
There are some instructions for RedHat 7.2 in the MapServer Wiki at
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH72
They're not completely up to date, but should help you get started.
Daniel
"Thomas P. Colson" wrote:
> I see there's this handy little guied for getting mapserver running with PHP on RH 6x,
> http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_redhat.html
> http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_faq.html
> http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html
> Is there a similar guide out there for RH 7x? (7.3, specifically). Has anyone gotten Mapserver to compile/run on RH 7.3? If so, what libs did you have to install, in what order, etc? Thanks.
> Tom Colson
