[mapserver-users] RE: PHP/MapScript compile errors
Thomas P. Colson
tpcolson at nexussoft.com
Thu Oct 31 13:04:26 EST 2002
When doing a make of 3.6.0 w/ php 4.2.3, I get the following...
Any ideas as to what could be causing this?
php_mapscript_util.o php_mapscript_util.c
gcc: cannot specify -o with -c or -S and multiple compilations
make[1]: *** [php_mapscript_util.o] Error 1
make[1]: Leaving directory `/home/src/mapserver-3.6.0/mapscript/php3'
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Thursday, October 31, 2002 12:04 PM
To: Thomas P. Colson
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] PHP/MapScript compile and install on
RedHat 7.x
"Thomas P. Colson" wrote:
> So....do I just re-install PHP, (Version 4.1.2 came with 7.3) or what levers do I need to pull to make mapscript work?
Yes you should build a new PHP, and install it as a CGI exactly as
described in the Wiki. You can use PHP 4.2.3 instead of 4.1.2 though...
it works very well. The Wiki is just a bit out of date on the latest
PHP version.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
