[mapserver-users] external links in a map
Ian Turton ian at geography.leeds.ac.uk
Thu Sep 5 05:24:20 EDT 2002
At 19:56 04/09/02, Ed McNierney wrote:
>Ian -
>While I don't disagree with your general approach, I think this is a very
>reasonable feature for MapServer, and I've been looking at it a bit
>myself.  If it's reasonable to let MapServer generate point symbols or
>polygons on a map image, and it's reasonable for MapServer to have a
>"query" mode in which you click on those things to produce querymaps of
>that feature, then I think it's equally reasonable for that server to
>generate flyover labels, etc. for the same feature.  It happens that HTML
>requires a completely different set of tags (imagemap) to do such a thing,
>but that's not MapServer's fault nor is it a good reason to not want
>MapServer to generate them.
>What I do not particularly want is two SEPARATE tools traversing the same
>data set to generate two related outputs unless there's a deterministic
>way to ensure they are consistent.  If GeoTools and MapServer don't render
>a polygon feature exactly the same way, my imagemap won't agree with my
>image.  That may or may not be important to my application.
I fact I was proposing using MapServer should generate the image
(preferably in WMS mode) while the client handles the pop ups or hovers
based on info from the server (possibly acting as a Web Feature Server
WFS). Certainly for hover/flyover labels you'd want to avoid the over head
of a HTTP call each time, it's hard to optimize that stuff in a single
program with out latency in too.
>GeoTools is CERTAINLY worth investigating for this particular problem, but
>do think that it's a reasonable thing to want MapServer to do.  Another
>good tool philosophy is that if you've got one tool that already knows how
>to do 90% of the job, it might be helpful to add the other 10%.  I think
>they're both useful ways of looking at a problem.
In fact someone else suggested how to do some of it in existing mapscript
so I'm off to read up on that as I'd previously overlooked templates in
that regard.
>         - Ed
>Ed McNierney
Ian
Ian Turton, Centre for Computational Geography, School of Geography,
University of Leeds, Leeds, LS2 9JT. ***0113 3433392 - New Phone No***
URL: http://www.geog.leeds.ac.uk/staff/i.turton/
