[mapserver-users] [OFF-TOPIC]FreeGIS like ArcFamily
Dave McIlhagga
mcilhagga at dmsolutions.ca
Tue Sep 10 18:52:38 EDT 2002
OpenEV can also do interpolations + you don't necessarily have to
translate your DGN to Shapes - they can be read directly by OpenEV via
OGR and rendered in 3D.
Dave
Tyler Mitchell wrote:
> -The GDAL/OGR package can read numerous raster and vector formats and write
> some of them as well. (http://www.remotesensing.org/gdal).
> -OpenEV can by default edit/create shapefiles and view data using the above
> mentioned libraries. It can also create 3d views (simple drapes) over
> elevation rasters!
> -I'd love to learn more about TIN/DTM options you find
> -I don't have any ideas around interpolation of point values except to
> check out GRASS GIS which, I believe can do most of what you are looking
> for.
> Tyler
> EDUARDO PATTO KANEGAE
> <EDUARDOPK at vcp.com.br> To: MapServer USERS (Correio eletrônico)
> Sent by: <mapserver-users at lists.gis.umn.edu>
> owner-mapserver-users at lists. cc:
> gis.umn.edu Fax to:
> Subject: [mapserver-users] [OFF-TOPIC]FreeGIS like
> ArcFamily
> 09/10/2002 12:42 PM
> is there any software or set of software, under the free-software, that
> would be possible to:
> - import data from CAD files( dxf, dgn)
> - work on .SHAPEFILE format
> - generates TIN/DTM
> - generates 3D Visualization of DTM surfaces
> - interpolation of point values
> well, i think the right question may be: is there a way of
> using free-software for making the same results( or nearest) that ESRI
> Arc* does?
> regards
> Eduardo Patto Kanegae
> eduardopk at vcp.com.br <mailto:eduardopk at vcp.com.br>
> Time Planejamento - UNIDADE LA - Ramal 9126
> eduardo at scopotecnologia.com.br <mailto:eduardo at scopotecnologia.com.br>
> http://www.scopotecnologia.com.br <http://www.scopotecnologia.com.br/>
Dave McIlhagga
President, DM Solutions Group
http://www.dmsolutions.ca
EMail : mcilhagga at dmsolutions.ca
Phone : 613-565-5056 x15
Fax : 613-565-0925
