[mapserver-users] Perl Mapscript issue (was: Tried to send messageto thelist..)
Brian Tomaszewski
btski at rochester.rr.com
Tue Sep 10 21:33:38 EDT 2002
Thank you for the reply Lowel
I modfied the map file and took out RASTER and postGIS references, and now
the error is just
[Tue Sep 10 21:45:56 2002] [error] [client 192.168.1.1] Premature end of
script headers: /usr/local/apache/cgi-bin/ms.cgi
Questions:
I am learning PERL as I learn mapscript, so could there be something with my
PERL installation?
In general, can you not use raster layers with mapscript ?
Any more ideas on things to look for?
Thank you
Brian
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu]On Behalf Of Lowell
Filak
Sent: Tuesday, September 10, 2002 5:12 PM
To: mapserver-users at lists.gis.umn.edu; btski at rochester.rr.com
Subject: Re: [mapserver-users] Perl Mapscript issue (was: Tried to send
Do you have RASTER layers in your mapfile? If you comment that layer(s) out
does the cgi work?
Lowell F.
> I tried to send a message to the MS list, but it didn't seem to go
through..
> However, nothing was sent back to me (wrong email).
> Here is my message:
> Hi List
> I am trying to run a very basic mapscript cgi. Here is the code:
> #!/usr/local/bin/perl
> use mapscript;
> my $map = new mapObj('/usr/local/apache/htdocs/liv_ms/liv.map') or
> die('Unable to open mapfile');
> my $image = $map->draw() or die('Unable to draw map');
> When I try to run, I get a 500 Internal server error in my browser and
the
> following is in the apache error log:
> [Mon Sep 9 21:25:25 2002] [error] [client 192.168.1.1] Premature end of
> libpng warning: Incomplete compressed datastream in iCCP chunk
> I have already checked:
> -perl is in /usr/local/bin/
> -there is a map file at the location
> Any help or ideas would be appreciated
> Thank you in advance
> Brian Tomaszewski
