[mapserver-users] method to check config of all old versions
Ellis Robin (Bundaberg) Robin.Ellis at nrm.qld.gov.au
Fri Sep 13 02:13:14 EDT 2002
I'm trying to work out the configuration of an older version of
Mapserver I have running (3.3.11) but am having no success. For versions
3.5+ I'm able to run this:
mapserv -v
And get the appropriate output, like this:
seqbbggis002 (ellisrj-3:20:26pm) /data4/WWW/cgi-bin> maptest -v
MapServer version 3.5 (pre-alpha) OUTPUT=GIF INPUT=TIFF INPUT=EPPL7
INPUT=POSTGIS INPUT=SHAPEFILE
however when I do this for the 3.3 version I get this:
seqbbggis002 (ellisrj-3:31:25pm) /data4/WWW/cgi-bin> mapserv -v
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
Can somebody point me in the right direction to get the info I need? I'm
running Mapserver on a Unix (Solaris) platform with Apache.
Thanks
Rob
Robin Ellis
Information & Knowledge
Department of Natural Resources and Mines
PO Box 1167
Bundaberg QLD 4670
ph +61 7 4131 5771
fax +61 7 4131 5823
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
