[mapserver-users] method to check config of all old versions
Ellis Robin (Bundaberg) Robin.Ellis at nrm.qld.gov.au
Sun Sep 15 18:18:01 EDT 2002
Thanks Ed, the simple solutions are always the best! I hadn't known that
info was included in the output files.
Thanks again
Rob
-----Original Message-----
Sent: Friday, 13 September 2002 9:38 PM
To: Ellis Robin (Bundaberg); MapSever Users (E-mail)
Subject: RE: [mapserver-users] method to check config of all old
versions
Ellis -
I don't have any pre-3.5 versions around to test, but can you look at
the HTML output of the older MapServer binary and see if it is inserting
a comment string (one that looks just like the "mapserv -v" output) at
the top of the HTML page.
	- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
From: Ellis Robin (Bundaberg) [mailto:Robin.Ellis at nrm.qld.gov.au]
Sent: Friday, September 13, 2002 2:13 AM
To: MapSever Users (E-mail)
Subject: [mapserver-users] method to check config of all old versions
I'm trying to work out the configuration of an older version of
Mapserver I have running (3.3.11) but am having no success. For versions
3.5+ I'm able to run this:
mapserv -v
And get the appropriate output, like this:
seqbbggis002 (ellisrj-3:20:26pm) /data4/WWW/cgi-bin> maptest -v
MapServer version 3.5 (pre-alpha) OUTPUT=GIF INPUT=TIFF INPUT=EPPL7
INPUT=POSTGIS INPUT=SHAPEFILE
however when I do this for the 3.3 version I get this:
seqbbggis002 (ellisrj-3:31:25pm) /data4/WWW/cgi-bin> mapserv -v This
script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
Can somebody point me in the right direction to get the info I need? I'm
running Mapserver on a Unix (Solaris) platform with Apache.
Thanks
Rob
Robin Ellis
Information & Knowledge
Department of Natural Resources and Mines
PO Box 1167
Bundaberg QLD 4670
ph +61 7 4131 5771
fax +61 7 4131 5823
The information in this e-mail together with any attachments is intended
only for the person or entity to which it is addressed and may contain
confidential and/or privileged material.
Any form of review, disclosure, modification, distribution and/or
publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to inform the
sender as quickly as possible and delete this message and any copies of
this message from your computer and/or your computer system network.
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
and/or publication of this e-mail message is prohibited.
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
