[mapserver-users] Two rasters covering each other at the
same scale
Steve Lime
steve.lime at dnr.state.mn.us
Sat Sep 14 12:56:12 EDT 2002
I assume what's happening is that you're running out of colors. When
that happen matches
are made based on proximity which can lead to some funky results. 3.7
should fix this with
24-bit PNG output. For older versions the only workaround is reducing
the number of colors
in images OR do some palette matching so that the images don't need as
many colors.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Branko Kmetec" <branko.kmetec at mb.birostroj-co.si> 09/12/02 10:43AM
Has someone idea, why do i get strange picture like on link:
http://mail.mb.birostroj-co.si/map.png. I get it only when two rasters
are covering at the same scale.
Here's also my map file:
MAP
EXTENT 369144 11687 630856 208313
IMAGECOLOR 255 255 255
IMAGEQUALITY 75
IMAGETYPE PNG
INTERLACE TRUE
SHAPEPATH "./data/"
SIZE 400 300
STATUS ON
TRANSPARENT FALSE
UNITS KILOMETERS
NAME "DARS d.d."
LEGEND
INTERLACE TRUE
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 255 255 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS OFF
TRANSPARENT FALSE
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
REFERENCE
COLOR -1 -1 -1
IMAGE "./images/slovenija.png"
OUTLINECOLOR 255 0 0
SIZE 100 75
STATUS ON
MARKER 0
MARKERSIZE 0
MINBOXSIZE 3
MAXBOXSIZE 0
END
SCALEBAR
BACKGROUNDCOLOR 1104913136 72 16057808
COLOR 255 255 0
INTERLACE TRUE
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 255 255 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
TRANSPARENT FALSE
UNITS MILES
END
WEB
IMAGEPATH "/usr/local/www/htdocs/dars_web/tmp/ac/"
IMAGEURL "/tmp/ac/"
MAXSCALE 1e+008
MINSCALE 5.0e+007
END
LAYER
DATA "ac-mala.png"
MINSCALE 5.5e+008
NAME "AC mala"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 3
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS METERS
CLASS
NAME "AC mala"
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 0
END
END
LAYER
DATA "ac.png"
MAXSCALE 5.5e+008
MINSCALE 1.0e+007
NAME "AC"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 3
TYPE RASTER
UNITS METERS
CLASS
NAME "AC"
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 0
END
END
LAYER
DATA "obroc.png"
MAXSCALE 2.0e+008
MINSCALE 1.0e+007
NAME "obroc"
SIZEUNITS PIXELS
STATUS DEFAULT
TOLERANCE 3
TYPE RASTER
UNITS METERS
CLASS
NAME "Obroc"
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 0
BACKGROUNDCOLOR 0 0 0
END
END
END
Regards,
Brane
