[mapserver-users] Problem with template file
Mark Giesbrecht
mgiesbrecht at geoarctic.com
Thu Sep 19 15:42:22 EDT 2002
Hi Matthew,
I think that it has to do with the fact that mapserver does not recognize the
.php4 extension as an web-based file, thus returning an error.
A solution you could try is to configure your web server setup (Apache, IIS?)
to recognize .html as an executable script, done so by PHP. I had seen this
in an old Linux Journal article, where it covered migrating an HTML based
site to PHP.
I can check this evening for the article, and can sum it for you if you'd
like.
Cheers,
Mark
Matthew Archer wrote:
> Hi,
> I have a problem using a php file as a temmplate. using 'map.html' works
> ok, using 'map2.php4' generates this error:
> Content-type: text/html msReturnPage(): Web application error. Malformed
> template name.
> Both files exist and their contents are the same (only html actually, no
> php code).
> Why????
> WEB
> TEMPLATE "map.html"
> # TEMPLATE "map2.php4"
> IMAGEPATH "c:\apache\htdocs\tmp\"
> IMAGEURL "\tmp\"
> END
> Matthew Archer
> T-Kartor Sweden AB
> Box 5097
> S-291 05 Kristianstad
> SWEDEN
> Phone: +46-(0) 44-206823
> Mobile: +46-(0)733-206823
> Fax: +46-(0) 44-128256
> mailto:ma at t-kartor.se
> http://www.t-kartor.se
> Kristianstad: http://www.karthotellet.com/map/?id=920
Type: text/x-vcard
Desc: Card for Mark Giesbrecht
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020919/1235a919/mgiesbrecht.vcf
