[mapserver-users] Compilation error for mapserver 3.7 (CVS) with flash output support
David Monterroso Cabello pyro-x at ixine.com
Tue Sep 24 14:39:49 EDT 2002
Hi there!
    I've been using mapserver for a while (the 3.6 versions), but now i
would like to experiment with the swf output feature. I downloaded the
sources from CVS configured and tried to compile it.
This was the configure command line:
[root at pyro-x mapserver]# ./configure
--with-php=/home/pyro-x/Downloads/php-4.2.0 --with-postgis --with-proj
--with-ming
And the result result:
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for c++... (cached) c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... (cached) yes
checking whether c++ accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for bison... (cached) bison -y
checking if compiler supports -R... (cached) no
checking if compiler supports -Wl,-rpath,... (cached) yes
checking for exp in -lm... (cached) yes
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for strcasecmp... (cached) yes
checking for strncasecmp... (cached) yes
checking for strdup... (cached) yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
checking which version of GD to use...
        using libgd from system libs.
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... yes
        using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
        using libpng from system libs.
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... no
checking for gdImageStringTTF in -lgd... yes
checking for gdImageString16 in -lgd... yes
checking for gdImageGifPtr in -lgd... no
        using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_TTF) from system libs.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... (cached) no
        libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
        using libtiff from system libs.
checking whether we should include EPPL7 support...
        including EPPL7 support.
checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
        using PROJ.4 from system libs.
checking whether we should include thread safe support...
        thread safe support disabled.
checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
        MPATROL support not requested.
checking whether we should include OGR support...
        OGR support not requested.
checking if GDAL support requested... no
checking if PostGIS support requested... yes
checking for pg_config... /usr/bin/pg_config
yes, user supplied pg_config
checking if OracleSpatial support requested... no
checking if MING/Flash support requested... yes
checking whether we should include WMS Server support...
        OGC WMS compatibility enabled (-DUSE_WMS_SVR).
checking whether we should include WMS Client Connections support...
checking whether we should include WFS Server support...
        OGC WFS Server support not requested.
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
checking for gcc -shared ... yes
checking for location of config.h or php_config.h...
/home/pyro-x/Downloads/php-4.2.0/main/php_config.h
checking whether we have PHP3 or PHP4... -DPHP4
checking whether we should use PHP's regex... no
        PHP/MapScript module configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
creating mapscript/php3/Makefile
    For me it seems everything is OK, but when i try to make the sources
i always get this error:
[root at pyro-x mapserver]# make
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H -DUSE_WMS_SVR   -DUSE_MING_FLASH  -DUSE_TIFF -DUSE_JPEG
-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF
-DUSE_POSTGIS   -I/usr/include           -I/usr/include    maptemplate.c
-o maptemplate.o
In file included from maptemplate.h:8,
                 from maptemplate.c:3:
map.h:1200: parse error before `httpRequestObj'
make: *** [maptemplate.o] Error 1
    If i don't include the ming library support it compiles without
problems, i tried it some weeks ago and today i updated the cvs tree but
it doesn't compile anyway :-\.
    Can you see something strange, in my config?.
Many Thanx
