[mapserver-users] POSTGIS parse error
Thomas Haechler
thaechl at geo.unizh.ch
Mon Sep 30 04:07:08 EDT 2002
Hi Alex
I recently had exactly the same problem. Did you perhaps restart your
database server and forgot to allow TCP/IP connections, i.e. forgot to
use the -i option when starting postmaster?
You can find the posting here:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00091.html
Read also Tyler's note on this:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00093.html
Btw, I have made very good experiences with the new version of
mappostgis.c from the 3.7 version, where you get much more detailed
error messages. See:
http://mapserver.gis.umn.edu/wilma/mapserver-users/0209/msg00300.html
Hope this helps you,
Thomy
Alexander Pucher wrote:
> Hi,
> for some strange reason, mapserver fails to select data from my local
> PostgreSQL DB with this error:
> Warning*: MapServer Error in msPOSTGISLayerOpen(): Error parsing POSTGIS
> connection information
> This was already posted on the list about a year ago, but with no real
> conclusion.
> Dave Blasby wrote back then:
> The message occurs if the postgresql client
> library returns a
> "CONNECTION_BAD" when it tries to open a connection.
> I have to add that everything used to work on my machine without
> problems until yesterday....
> Did anyone come across this problem recently?
> Any suggestions?
> Regards,
> alex
> ________________________________________________________
> Institut fuer Geographie und Regionalforschung
> Universitaet Wien
> Kartografie und Geoinformation
> Departement of Geography and Regional Research
> University of Vienna
> Cartography and GIS
> Universitaetstr. 7, A-1010 Wien, AUSTRIA
> Tel: (+43 1) 4277 48644
> Fax: (+43 1) 4277 48649
> E-mail: alexander.pucher at univie.ac.at
> FTP: ftp://ftp.gis.univie.ac.at
> WWW: http://www.gis.univie.ac.at/karto
> Atlas of Eastern and Southeastern Europe: http://www.aos.ac.at
> M$ is not the answer. M$ is the question!
> No is the answer -- Eric Naggum
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
