[Mapserver-users] wms and scalebar
Arnulf Christl
arnulf.christl at ccgis.de
Tue Apr 1 11:00:03 EST 2003
The WMS interface only defines a method to retrieve maps (and a little
FeatureInfo) nothing around. Therefore the MapServer feature "scalebar"
cannot be used directly when accessing the server via WMS because it is not
a map. MapScript can do it because it does not restrict itself to be OGC
compatible.
It will probably be better to include the scalebar directly into your
client. To do that your client has to be able to create a scalebar itself.
As the client anyway exactly knows where in the world it is and how many
pixel it needs to display the map this should be no problem.
Regards,
Arnulf Christl.
We have moved! Plesae send snail mail to this adress:
CCGIS GbR
Siemensstraße 8
53121 Bonn
GERMANY
www.ccgis.de
Phone: +49 (0) 228 90826 0
Direct: +49 (0) 228 90826 23
Fax: +49 (0) 228 90826 11
GSM: +49 (0) 172 2958 004
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Petur
Kirke
Gesendet: Dienstag, 1. April 2003 14:09
An: MapServer
Betreff: [Mapserver-users] wms and scalebar
Hello
Is it possible to recieve a scalebar, when making a wms call to the wms
server ?
Or is the scalebar only useful for MapServer applications, that are not wms
applications ?
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
