[Mapserver-users] JPEG input
Ed McNierney
ed at topozone.com
Wed Apr 2 08:47:57 EST 2003
Jan -
No, you need to eliminate the two different JPEG libraries from the build. In your case, that means modifying the GD build to link with the GDAL JPEG library.
- Ed
-----Original Message-----
Sent: Wednesday, April 02, 2003 8:28 AM
To: Ed McNierney
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] JPEG input
I did that too! I commented out the three lines for JPEG support in
MapServer's Makefile.vc, but the result was the same.
Jan
Ed McNierney wrote:
> Jan -
> Please forgive my incomplete recollection, but I ran into this same problem a long time ago. It appears that the JPEG library inside GDAL is built slightly differently than the default jpeg-6b library (although it's the same version), and the two are not compatible. I suspected it was a structure packing/alignment issue (i.e. the files are the same but they're compiled differently). I decided not to look into it and simply use the JPEG support from GDAL and remove the jpeg-6b library from my build. That fixed the problem.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> From: Jan Hartmann [mailto:jhart at frw.uva.nl]
> Sent: Wednesday, April 02, 2003 6:19 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] JPEG input
> Hello,
> I'm trying to display a jpeg input image and get the following error
> message:
> JPEG parameter struct mismatch: library thinks size is 432, caller
> expects 464
> Platform: Win2000, VC++
> Mapserver: CVS, compiled with and without JPEG input support (jpeg-6b)
> GD: 2.0.11, compiled with jpeg-6b
> GDAL: 1.1.8
> I diffed the jpeg files under GDAL with the jpeg-6b distribution and
> found no differences. Yet there seems to be a version mismatch
> somewhere. Outputting JPEG is no problem. Has anyone any ideas?
> Jan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
