[Mapserver-users] Re: [Fwd: [Fwd: problems installig mapscript extension]]
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Apr 2 10:29:59 EST 2003
Hi There,
The reason may be that some dll's needed by php_mapscriopt_36.dll were not
found. Are you using php/mascript downloaded from
www2.dmsolutiu0ons.ca/mapserver/dl/ site ? If it is the case the zip files
conatins several dll's that should be installed in your system directory
(please refer to the README).
Make sure also to use php_mapscript dll that was built for the version of
PHP you are running.
I also recommend using an utility tool called
http://www.dependencywalker.com/ that will show you if depending dlls are
missing.
Later,
PS : please use the mapserver user list for these issues since It will be
seen by more people and will increase the chance of getting an answer. It
will also benefit all the community when a problem is fixed.
> -------- Original Message --------
> Subject: problems installig mapscript extension
> Date: Wed, 2 Apr 2003 12:09:00 -0000
> From: Pedro Brito <apbbo at iscte.pt>
> Reply-To: Pedro Brito <apbbo at iscte.pt>
> To: <info at dmsolutions.ca>
> Hi
> I´m having problems intaling mapscript extension for php in my computer,
> can you help me?
> I use Apache 1.3.22 amd PHP 4.06.
> I copy the php_mapscript_36.dll into ../php/extension and added that in
> php.ini
> After that when I start Apache it tells me that there is a problem in
> dllcore and that i can not find php_mapscript_36.dll. If I don´t add
> php_mapscript_36.dll to php.ini it work fine. I also edit the extension
> path and that I know it´s working fine because if I install onether
> extension it work fine.
> So can you please help me??? I hope you can.
> Many Thanks
> Pedro Brito
> mail : pedro_brito at yahoo.com
> arnaldo.brito at iscte.pt
> url : http://www.pedro-brito.pt.vu
> ________________________________________________
> This mail was sent by UebiMiau 2.5
> Jody Cloutier
> Marketing Specialist
> DM Solutions Group
> cloutier at dmsolutions.ca
> tel: 613.565.5056 ext. 13
> fax: 613.565.0925
> www.dmsolutions.ca
> Dave McIlhagga
> President, DM Solutions Group
> http://www.dmsolutions.ca
> EMail : mcilhagga at dmsolutions.ca
> Phone : 613-565-5056 x15
> Fax : 613-565-0925
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
