Fw: [Mapserver-users] installation problems
Petur Kirke peturkirke at fds.fo
Wed Apr 2 09:39:45 EST 2003
I think so, because the demo_init.html file seems to work fine in the
browser
----- Original Message -----
To: "Petur Kirke" <peturkirke at fds.fo>
Sent: Wednesday, April 02, 2003 5:29 PM
Subject: Re: [Mapserver-users] installation problems
> Dear Petur,
> are you sure, that the direcztory, where you placed the demo-files is
> given free for your webserver? You need to create the directory in the
> config-file of your webserver, otherwise you don't have access to it via
> the HTTP.
> Till
> Petur Kirke schrieb:
>  > I have installed MapServer on a Windows server.
>  > Because the default web application on this server is located on the
>  > d:\partition, I have i installed the demo application on the d:\
> partition
>  > as well.
>  > I have installed mapserv.exe on c:\inetpub\scripts and I have mapped
this
>  > directory as "cgi-bin".
>  > I have installed the other files just as the dokumentation says, I
should
>  > do.
>  > But I cant get this to work. The demo_init.html file seems to work
> fine, but
>  > when I click on "Initialize", I get the message:
>  > "The page cannot be found"
>  > even if it seems like all parameters are right !
>  > I have changed the demo_init.html file just as the documentation says,
I
>  > should do.
>  > Does anyone know, what the problem is here ? Could it be a problem,
> that I
>  > have installed the demo application on the d:\ partition ?
>  > _______________________________________________
>  > Mapserver-users mailing list
>  > Mapserver-users at lists.gis.umn.edu
>  > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> ***** terrestris ist umgezogen !!! Neue Adresse siehe unten ************
> ***** Bald !! AveiN! 1.2 Die MapServer Erweiterung für ArcView GIS *****
> Dipl. Geogr. Till Adams
> terrestris, Paulsen&Adams GbR
> Siemensstr. 8 * 53121 Bonn
> Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> info at terrestris.de * www.terrestris.de
