[Mapserver-users] Sending String Logical Expressions
woodbri at swoodbridge.com
Wed Apr 2 11:26:59 EST 2003
James,
Try $qclass->setexpression("(". ${qstring}. ")");
I have run into a case on PHP4 today where this worked but you
example did not. Not sure why, just happy to have a fix :)
-Steve W.
On 2 Apr 2003 at 10:45, James Vogl wrote:
> Hi All,
> The write-up PHPMapScriptMySQLShapeFiles for the mapserver-users forum
> was instrumental in getting me started in PHP and Mapscipt. However,
> I've come across a problem I haven't been able to solve.
> I have constructed a simple HTML web form in which users enter a
> SQL-like
> formula into a single textbox. Using a simple GET form and submit
> button, the single textbox value gets sent to a PHP file. The method
> works fine for queries on numeric fields in which the user enters:
> [Block]= 500 and [I_o] = 1.
> But Mapserver fails to return any results when a text field is
> specified like so:
> '[Street_Nam]' = "MAIN"
> or to avoid sending special characters:
> ‘[Street_nam]’="MAIN"
> By using the echo command in the receiving PHP I'm able to confirm
> that the proper string is being sent:
> echo "<br>The string sent is $qstring<br>";
> In this case value returned is:
> The string sent is '[Street_Nam]=\"MAIN\"
> If I explicitly specify the value for setexpression as such:
> $qclass->setexpression("('[Street_Nam]' = \"MAIN\")");
> the query works fine.
> However, the following expression does not:
> $qclass->setexpression("(${qstring})");
> I wonder if the problem may be a lack of clarity as to how PHP parses
> string variables.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
