[Mapserver-users] Point symbol rendering problem (in GD?)
Havard Tveite
havard.tveite at ikf.nlh.no
Fri Apr 4 04:19:53 EST 2003
I have tested the symbol functionality of the development
version of Mapserver, and have had some problems with the
rendering of filled vector symbols.
Rendering with an outline gives the expected results, while
rendering without an outline gives "unexpected" results.
Problem:
When there is a horizontal line making up a lower border
of a filled area of the symbol, one row of pixels will be
missing along this line. (a line that is at the complete
bottom of the symbol is rendered OK). For a horizontal
line making up ab upper border, there is no problem.
The "error" seems so come from the "YX" algorithm used in
"gdImageFilledPolygon", and should have nothing to do with
mapserver.
I am using GD 2.0.12 now, but the problem was there also
before I upgraded.
Example:
Using the symbol
SYMBOL
NAME "vplus"
TYPE vector
FILLED true
POINTS
1 0 2 0 2 1 3 1 3 2 2 2 2 3 1 3 1 2 0 2 0 1 1 1 1 0
END
END
Produces the following
Symbol size 3, no outline:
XX
XXXX
XX
XX
Symbol size 3, with outline:
XX
XXXX
XXXX
XX
Symbol size 7:
XXXX
XXXX
XXXXXXXX
XXXXXXXX
XXXXXXXX
XXXX
XXXX
XXXX
XXXX
XXXX
XXXXXXXX
XXXXXXXX
XXXXXXXX
XXXXXXXX
XXXX
XXXX
I have also tested this for vector boxes with holes, and
the same problem appears.
A work around is to always render filled vector symbols
with an outline.
Håvard Tveite Phone: +47 64948857
Department of Mapping Sciences Fax: +47 64948856
Agricultural University of Norway http://www.nlh.no/ikf
Hogskoleveien 14, POBox 5034, N-1432 Ås, NORWAY
