[Mapserver-users] installation problems
Petur Kirke peturkirke at fds.fo
Mon Apr 7 02:59:28 EDT 2003
The answer's i got on this question wasn't wery helpful, but thank you
anyway
but anyway - now I have solved the problem, which was an ISAPI filter, that
did prevent exe files to be executed on the web server.
----- Original Message -----
From: "Fawcett, David" <David.Fawcett at state.mn.us>
To: "MapServer" <mapserver-users at lists.gis.umn.edu>; "'Petur Kirke'"
<peturkirke at fds.fo>
Sent: Wednesday, April 02, 2003 6:16 PM
Subject: RE: [Mapserver-users] installation problems
> I believe that the Initialize page is just an html page and doesn't call
the MapServer executable.
> It sounds like you either haven't correctly set the URL for the
mapserv.exe or you have a directory rights issue.
> David.
> David J. Fawcett
> GIS / Databases
> MN Office of Environmental Assistance
> 520 Lafayette Rd N
> St. Paul, MN 55155
> 651.215.0200
> > From: Petur Kirke[SMTP:peturkirke at fds.fo]
> > Sent: Wednesday, April 02, 2003 8:39 AM
> > To: MapServer
> > Subject: Fw: [Mapserver-users] installation problems
> > I think so, because the demo_init.html file seems to work fine in the
> > browser
> > From: "Till Adams" <adams at terrestris.de>
> > To: "Petur Kirke" <peturkirke at fds.fo>
> > Sent: Wednesday, April 02, 2003 5:29 PM
> > Subject: Re: [Mapserver-users] installation problems
> > > Dear Petur,
> > > are you sure, that the direcztory, where you placed the demo-files is
> > > given free for your webserver? You need to create the directory in the
> > > config-file of your webserver, otherwise you don't have access to it
via
> > > the HTTP.
> > > Till
> > > Petur Kirke schrieb:
> > >  > I have installed MapServer on a Windows server.
> > >  > Because the default web application on this server is located on
the
> > >  > d:\partition, I have i installed the demo application on the d:\
> > > partition
> > >  > as well.
> > >  > I have installed mapserv.exe on c:\inetpub\scripts and I have
mapped
> > this
> > >  > directory as "cgi-bin".
> > >  > I have installed the other files just as the dokumentation says, I
> > should
> > >  > do.
> > >  > But I cant get this to work. The demo_init.html file seems to work
> > > fine, but
> > >  > when I click on "Initialize", I get the message:
> > >  > "The page cannot be found"
> > >  > even if it seems like all parameters are right !
> > >  > I have changed the demo_init.html file just as the documentation
says,
> > I
> > >  > should do.
> > >  > Does anyone know, what the problem is here ? Could it be a problem,
> > > that I
> > >  > have installed the demo application on the d:\ partition ?
> > >  > _______________________________________________
> > >  > Mapserver-users mailing list
> > >  > Mapserver-users at lists.gis.umn.edu
> > >  > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > ***** terrestris ist umgezogen !!! Neue Adresse siehe unten
> > > ***** Bald !! AveiN! 1.2 Die MapServer Erweiterung f> ür ArcView GIS
> > > Dipl. Geogr. Till Adams
> > > terrestris, Paulsen&Adams GbR
> > > Siemensstr. 8 * 53121 Bonn
> > > Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
> > > info at terrestris.de * www.terrestris.de
