[Mapserver-users] Where are legend, reference and .qy images stored? MORE INFO
Paul Peterson pwpeterson at iesc.net
Mon Apr 7 12:01:49 EDT 2003
Gerry, et al...
I did some more testing.  I discovered to get the ref, leg and *.qy files
stored the IMAGEPATH directory MUST be assigned the ownership and group of
the web server.  In my case when I changed both of these to 'apache' the
images were generated and stored, however, again they are showing up in
/var/tmp!!!!  They never get displayed along with the map image because the
process tries to get them from /var/www/html/tmp as it should.
My .map file is in /var/www/html/tutorial/s3/
Expected tmp directory /var/www/html/tmp
The IMAGEPATH and IMAGEURL are:
IMAGEPATH "../../tmp/"
IMAGEURL "/tmp/"
Apache serves html from /var/www/html
Paul Peterson
Gerry's response:
May be a 3.7 "feature"... I've not seen image evolution here, either.
gerry
Paul Peterson wrote:
> Rich, Thank you for your response
> I should have been more specific...
> IMAGEURL "/tmp/"
> Apache server html from /var/www/html
> I give the tmp directory +777 permission which is drwxrwxrwx.
> All the images should be placed in /var/www/html/tmp, however, only the
map
> image is.  I found the others (ref, leg and .qy) in /var/tmp!
> I add a tmp directory (/var/www/html/tutorial/s3/tmp) and made these
changes
> to IMAGEPATH and IMAGURL:
> IMAGEPATH "tmp/"
> IMAGEURL "/tutorial35/s3/tmp/"
> Again, the only image that shows up there is the map image and I can't
find
> the others anywhere.
> Is this a bug with 3.7?
> Paul
> Rich's response:
> The images for the map, reference map, legend, and query files will all be
> saved to the IMAGEPATH directory, which is relative to the .map file. So
in
> your case it looks like your map file is in /var/www/html/tutorial35 and
> ../../tmp/ would put you at /var/tmp/. Is your webserver aliasing /tmp to
> /var/tmp/? Check the time stamps on the files in /var/www/html/tmp. Try
> seleting everything in both /var/tmp/ and  /var/www/html/tmp and then hit
> mapserver and see where the images files appear, because what you describe
> below does not quite make sense.
> Rich
> At 06:02 PM 4/6/2003 -0500, you wrote:
>>Hello all.
>>I wrote yesterday regarding a problem with my legends and reference images
>>not showing up.  Does MapServer (3.7) store all generated images in the
the
>>same tmp directory.  I am testing out the Tutorial35 demo app and it is
>>located at /var/www/html/tutorial35.  I have a tmp directory
>>/var/www/html/tmp where only the map png files are showing up.  I was
> trying
>>out the cashed query and discovered that the legend, reference and *.qy
>>files where being stored in /var/tmp.
>>Where in the map file does the directory for the legend, reference and .qy
>>files get set?  If MapServer is smart enough to store these files there
why
>>isn't it smart enough to download them from there as well?
>>A snippet of the map file follows:
>>NAME S3EX4
>>EXTENT -97.5 41.619778 -82.122902 49.38562
>>SIZE 400 300
>>SHAPEPATH "../data"
>>FONTSET "../fonts/fonts.list"
>>SYMBOLSET "../symbols/symbols35.sym"
>>WEB
>>  HEADER header.html
>>  TEMPLATE s3ex4.html
>>  FOOTER footer.html
>>  IMAGEURL "/tmp/"
>>  LOG /var/www/html/mapserver.log
>>END
>>Again the IMAGEPATH and IMAGEURL as defined above work for the map png,
but
>>not the legend, reference ro .qy files.
>>Any ideas what I am doing wrong?
>>Paul Peterson
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> (307) 733-0203
> Rich at GreenwoodMap.com
> www.GreenwoodMap.com
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
