[Mapserver-users] php_mapscript from cvs undefined symbol: cu rl_multi_info_read
Tyler Mitchell
TMitchell at lignum.com
Mon Apr 7 12:23:48 EDT 2003
Thanks JF,
I've got curl 7.10.4 and did the ldd check, things look fine there, but
still no go. I'll pick away some more. Thanks again.
[root at home no-debug-non-zts-20020429]# ldd php_mapscript_37.so
libcurl.so.2 => /usr/lib/libcurl.so.2 (0x400d2000)
libz.so.1 => /lib/libz.so.1 (0x400f3000)
libssl.so.0 => /usr/lib/libssl.so.0 (0x40102000)
libcrypto.so.0 => /usr/lib/libcrypto.so.0 (0x40130000)
libdl.so.2 => /lib/libdl.so.2 (0x401eb000)
libming.so => /usr/lib/libming.so (0x401ee000)
libpq.so.2 => /usr/lib/libpq.so.2 (0x4022e000)
libgdal.1.1.so => /usr/local/lib/libgdal.1.1.so (0x40241000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x404dc000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40518000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40539000)
libpng12.so.0 => /usr/lib/libpng12.so.0 (0x4057a000)
libpdf.so.1 => /usr/local/lib/libpdf.so.1 (0x405a3000)
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4065e000)
libstdc++-libc6.2-2.so.3 => /usr/lib/libstdc++-libc6.2-2.so.3
(0x40696000)
libm.so.6 => /lib/libm.so.6 (0x406e4000)
libc.so.6 => /lib/libc.so.6 (0x40706000)
libcrypt.so.1 => /lib/libcrypt.so.1 (0x40842000)
libresolv.so.2 => /lib/libresolv.so.2 (0x4086f000)
libnsl.so.1 => /lib/libnsl.so.1 (0x40881000)
libungif.so.4 => /usr/lib/libungif.so.4 (0x40897000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x408a0000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x408af000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
Jean-Francois.Doyon at CCRS.
NRCan.gc.ca To: TMitchell at lignum.com, mapserver-users at lists.gis.umn.edu
cc:
04/07/2003 08:49 AM Fax to:
Subject: RE: [Mapserver-users] php_mapscript from cvs undefined
symbol: cu rl_multi_info_read ?
Tyler,
I don't know about this specific error, but make sure you have LibCURL >=
7.10 ...
Also, make sure your php_mapscript_37.so is linked against libcurl by doing
a "ldd php_mapscript_37.so" and checking the output of that command (Should
work on Linux and Solaris at least).
Hope this helps,
J.F.
-----Original Message-----
From: Tyler Mitchell [mailto:TMitchell at lignum.com]
Sent: Monday, April 07, 2003 11:36 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] php_mapscript from cvs undefined symbol:
curl_multi_info_read ?
Hi all,
I updated from cvs over the weekend to the latest greatest, adding curl,
etc as per migration instructions for 3.7.
>From within my gmap application I'm getting the notice:
Warning: Unable to load dynamic library
'/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript_37.so
/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript_37.so:
undefined symbol: curl_multi_info_read in /var/www/gmap/htdocs/gmap75.phtml
on line 63
Anyone give me some pointers on what problems:
...is related to?
TM
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
