[Mapserver-users] Anyone used latest cvs?
woodbri at swoodbridge.com woodbri at swoodbridge.com
Mon Apr 7 21:19:01 EDT 2003
ALSO check for the includes.
rpm -e curl
rpm -e curl-devel
will remove the rpm versions. If you don't do the second then you
leave the headers.
-Steve W.
On 7 Apr 2003 at 20:49, Daniel Morissette wrote:
> Tyler Mitchell wrote:
> > Hi all,
> > I'm trying to track down some problems I'm having.  Has anyone else
> > download from cvs in the last day and got things working okay
> > (particularly with curl)?
> Hi Tyler,
> I built MapServer from the latest 3.7 CVS using both libcurl 7.10.4
> and 7.10.2 and it works fine for me.
> With respect to the problems with curl_multi_info_read that you
> reported in another thread, I would suggest that you check on your
> system and make sure that you don't have two copies of libcurl.so.2
> (i.e. one in /usr/lib and one in /usr/local/lib), if you do then make
> sure you remove the older one (which is quite likely coming from a
> RedHat RPM).  FYI, I remember running into some odd problems in the
> past after upgrading curl 7.x on RH systems because the library is
> called libcurl.so.2 in both the old (RPM) version and in the new
> compiled (7.10.x) version.  I'm ashamed to have to say that in this
> case it seemed that rebooting the Linux machine was the only way to
> force it to see the newer version of the libary after the RPM was
> removed.
> Daniel
>  Daniel Morissette               morissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
