[Mapserver-users] 50 classes and thicker lines
Michael Schulz
mschulz at webgis.de
Tue Apr 8 10:23:39 EDT 2003
map.h defines MS_MAXCLASSES as 50. This value is compiled into the mapserver
binary, you will need a new mapserver binary with that value changed prior to
compiling. You can't change it afterwards.
If you are using the default symbol for your layer they are always set to the
size of one pixel (doesn't matter if point, line or polygon). More information:
http://mapserver.gis.umn.edu/doc/mapfile-reference.html#class
look for keyword SYMBOL.
You could just define a simple point symbol of your own, use it in your layer
definition with
symbol "mysymbolname"
then you can use the size parameter.
Example symbol definition you could use for points and lines:
SYMBOL
NAME "mysymbolname"
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
HTH, Michael
"Strobl, Christian" schrieb:
> hello,
> excuse me for the simple question but i found no description or reference in
> the internet. is there any restriction of the number of classes in mapserver
> 3.63. it seems that 51 or 52 classes are to much for the mapserver (Windows
> Binary Download).
> thanks and greetings from munich
> christian
> p.s. is it possible to get thicker lines with mapserver? the size-parameter
> doesn't work.
> > christian strobl
> > diplom-geologe
> > bayerisches geologisches landesamt
> > heßstraße 128
> > d-80797 münchen
> > telefon: (089) 9214-2774
> > christian.strobl at gla.bayern.de
> > http://www.bayern.de/gla
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
