[Mapserver-users] MapFile - DATA question
Richard Greenwood
Rich at GreenwoodMap.com
Tue Apr 8 14:00:50 EDT 2003
--=======45E62BA6=======
Content-Type: text/plain; x-avg-checked=avg-ok-9E176DD; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 8bit
It looks like you are using postgis. Below are a few examples of changing
the filter clause. The %form_variable% substitutes the value from the form
variable. I tried this with the data statement, but had limited success.
FILTER "pidn = '%pidn%' "
FILTER "pidn like '%pidn%%' " # note the extra % for wild card
FILTER "(distance (table1.the_geom, (select the_geom from table1 where
pidn='%pidn%')) < %rad%)"
Rich
At 12:40 PM 4/8/2003 -0300, you wrote:
>Hi!!!
>Has anyone modified the DATA tag through the mapserv cgi params?
>or the question would be: It is possible to change the DATA tag using
>mapserv cgi params?
>In this example, we modified the 'map size' property.
>http://localhost/cgi-bin/mapserv?map=/var/www/html/ews/v0.7/files/map/m4.map&mode=map&map_size=450+600
>We would like to change the 'DATA' property along diferent calls.
>For example:
>time 0:
>data='the_geom from table1'
>time 1:
>DATA='the_geom from table2'
>time 2:
>DATA='the_geom from table2 where population > 100000'
>etc.
>Thanks in advance.
>Ariel
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
--=======45E62BA6=======--
