[Mapserver-users] Installation with PHP on Unix
Vincent Schut
schut at sarvision.com
Wed Apr 9 09:43:06 EDT 2003
Agneta,
Though I'm a linux - not unix - user, your problem sounds familiar.
Some checks that could shine light in this mapserver-darkness and prevent you
from doing only mapserver compilations till your 65th birthday... :
If you check your php info page (you should have something like phpinfo.php
somewhere) what does that tell you about the used regex?
Did you compile php with --with-regex=system? The old option
'--with-system-regex' is depricated since version 4.3.1, no matter what
mapserver tells you...
Have you checked the configure and make output of php (I know it's a lot...)
to check whether it really compiled a cgi, not a apache module?
Mind also that when compiling mapserver, the last version of php you compiled
counts. If you use 2 seperate versions of php, e.g. a apache module (apxs)
and a cgi, you should compile the cgi *after* the apache module, otherwise
mapserver will give you this same complaint. It only detects your last php
compilation. Another solution in this case is to put the 2 versions in 2
different directories (--prefix=.....).
Hope these help you further,
Vincent Schut.
On Tuesday 08 April 2003 16:53, Agneta Schick wrote:
> Hello MapServer-users,
> I don't know how often other users needed to compile the Mapserver
> and necessary components - I needed quite a number of tries until
> I had Perl MapScript running.
> And now I want to try PHP MapScript. Is anyone offended if I try a shortcut
> and ask who has the right configuration for
> php-4.3.1
> Mapserver 3.6.5
> Apache 1.3.22
> on Solaris 8
> I configured PHP as CGI but Mapserver-configure complained
> "re-compile PHP4 with --with-system-regex "
> so I did and then Mapserver-configure complained again
> "re-compile PHP4 with --with-system-regex ".
> This will keep me busy until I retire!
> I'm grateful if a Unix user will share his installation experience with me.
> Agneta Schick
>~~ Agneta Schick
> Bundesanstalt fuer Geowissenschaften und Rohstoffe
> Federal Institute for Geosciences and Natural Resources
> Stilleweg 2
> D- 30655 Hannover Tel.: +49 511 643 3136
> GERMANY FAX.: +49 511 643 3663
> schick at sdac.hannover.bgr.de http://www.seismologie.bgr.de
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
