[Mapserver-users] Layer color for point data
Michael Soracco
Michael.Soracco at noaa.gov
Fri Apr 11 10:47:10 EDT 2003
--------------2133C94FC0ED79C6CCD79868
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
I'm running mapserver 3.6 on RH Linux 7.2 with PNG, JPEG, Shapefile
support compiled statically.
Using the executible on one system yields expected results. When used
on another linux system (same OS, etc) with the identical map file
(modified for data layer locations), the map functionality exists (pan,
zoom, query) but point shapefile layers do not get drawn according to
the COLOR setting in the LAYER block n the map image. Although they do
show up with the designated color (red) on the reference image/ legend.
The polygon data in the map image are also color coded and are drawn
correctly. I'd suspect I've reached the number of colors limitation for
PNG, but since it works on one system and not the other I don't think
that's the problem. Also, Photoshop shows only about 14 colors in use
and they are identical except for the point data.
Any ideas on how to fix / troubleshoot this to determine where the
problem lies? I suspect I'll have to install the appropriate libaries
on the 'another system' and recompile mapserver to eliminate the
executable as the source of the problem.
from system 1 (red cities) and then again from system 2 (declared red in
mapfile, but display black)...The cities should be red....
[Image]m[Image]
Thanks for any suggestions.
-m
Content-Type: multipart/related;
boundary="------------454E078FD80A647C6A9090CF"
--------------454E078FD80A647C6A9090CF
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
I'm running mapserver 3.6 on RH Linux 7.2 with PNG, JPEG, Shapefile support
<p>Using the executible on one system yields expected results. When
used on another linux system (same OS, etc) with the identical map file
zoom, query) but point shapefile layers do not get drawn according to the
The polygon data in the map image are also color coded and are drawn correctly.
I'd suspect I've reached the number of colors limitation for PNG, but since
it works on one system and not the other I don't think that's the problem.
Also, Photoshop shows only about 14 colors in use and they are identical
<p>Any ideas on how to fix / troubleshoot this to determine where the problem
lies? I suspect I'll have to install the appropriate libaries on
the 'another system' and recompile mapserver to eliminate the executable
<p>from system 1 (red cities) and then again from system 2 (declared red
in mapfile, but display black)...The cities should be red....
<br><img SRC="cid:part1.3E96D56E.238D23C at noaa.gov" height=500 width=350>m<img SRC="cid:part2.3E96D56E.238D23C at noaa.gov" height=500 width=350>
<br>
<p>Thanks for any suggestions.
<br>-m</html>
Content-Type: image/png
Content-ID: <part1.3E96D56E.238D23C at noaa.gov>
Content-Transfer-Encoding: base64
Content-Disposition: inline; filename="C:\DOCUME~1\msoracco\LOCALS~1\Temp\nsmailG1.png"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Content-ID: <part2.3E96D56E.238D23C at noaa.gov>
Content-Disposition: inline; filename="C:\DOCUME~1\msoracco\LOCALS~1\Temp\nsmailNO.png"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--------------454E078FD80A647C6A9090CF--
--------------2133C94FC0ED79C6CCD79868--
