[Mapserver-users] Scalebar showing wrong units
Thorsten Fischer
thfischer at mapmedia.de
Mon Apr 14 11:51:00 EDT 2003
On Mon, 2003-04-14 at 12:35, Michael Härtel wrote:
> I try to set up an internet map with MapServ3.6 but it seems that the
> scalebar alsways shows the wrong units (refer to:
> "http://134.76.76.96/cgi-bin/mapserv.exe?map=H:\_webroot_\MapServ\nbu\nbu.map")
You are missing a line in the mapfile that says which kind of units make
up the final map. As you are using decimal degrees or your output image,
the solution is most likely to add a line saying
UNITS DD
to the header of your mapfile.
hth,
thorsten
