[Mapserver-users] masking
Norman Vine
nhv at cape.com
Mon Apr 14 14:37:59 EDT 2003
Aaron D. Hunt writes:
> Is there anyway to make a mask in mapserver?
> I need to block out anything outside of a polygon.
Not really sure what you are asking but you can draw
a *large" polygon in the desired background color as
the topmost layer with a 'tranparent' polygon cutout for
the area you want the map rendered in
Or you can use mapscript to modify the image
HTH
Norman
