[Mapserver-users] Re: mapserver postgis query error (explain verbose)
David Blasby dblasby at refractions.net
Mon Apr 14 16:55:57 EDT 2003
This is a multi-part message in MIME format.
--------------010709050900000403030207
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Leah Roderman wrote:
>I'm just checking to see if there's a fix for the Mapserver query of a PostGIS layer that produces the "explain verbose" error included below. I see PostGIS 0.7.5 was released last week -- there was some discussion around this error earlier this month, but not sure whether this problem got addressed in the new release.
>My alternative solution was going to be pgsql2shp, so I'd also be interested in anyone's success or frustrations with similar attempts.
Yes there is a fix.  I sent it out to a few people last week and they
have indicated it works fine and hasnt caused any new problems.
It does leak about 1.5kb of memory/layer at the moment - this should not
be a problem for you.  When I fix that I'll commit it to v3.6 CVS.
Until then, mappostgis.c is attached.
dave
ps. The 3.6 and 3.7 mappostgis.c used to be exactly the same.  This is,
unfortunately, no longer the case - someone changed some of the map.h
fields and that required changes in "mappostgis.c".  If you are using a
very modern mapserver, this mappostgis.c will not work.  You'll know
right away at compile time if there's a problem.
It'll be a little bit before I merge in the 3.7 changes and commit it.
 name="mappostgis.c"
Content-Disposition: inline;
 filename="mappostgis.c"
#include "map.h"
#ifndef FLT_MAX
#define FLT_MAX 25000000.0
#endif
#ifdef USE_POSTGIS
#ifndef LITTLE_ENDIAN
#define LITTLE_ENDIAN 1
#endif
#ifndef BIG_ENDIAN
#define BIG_ENDIAN 2
#endif
#include "libpq-fe.h"
#include <string.h>
typedef struct ms_POSTGIS_layer_info_t
	char		*sql;		//sql query to send to DB
	PGconn     *conn; 	//connection to db
	long	 	row_num;  	//what row is the NEXT to be read (for random access)
 	PGresult   *query_result;//for fetching rows from the db
	char		*urid_name; // name of user-specified unique identifier or OID
	char		*user_srid; //zero length = calculate, non-zero means using this value!
} msPOSTGISLayerInfo;
char tolower(char c)
	if ((c <'A') || (c>'Z'))
		return c;
	return c-'A'+'a';
//remove white space
//dont send in empty strings or strings with just " " in them!
char* removeWhite(char *str)
	int initial;
	char *orig,*loc;
	initial = strspn(str, " ");
	if (initial != 0)
		memmove(str, str+ initial, strlen(str) - initial+1);
	//now final
	if (strlen(str) == 0)
		return str;
	if (str[ strlen(str)-1] == ' ')
		//have to remove from end
		orig = str;
		loc = &str[ strlen(str)-1];
		while (( *loc = ' ') && (loc >orig) )
			*loc = 0;
			loc--;
	return str;
char *strstrIgnoreCase(char *haystack, char *needle)
	char *hay_lower;
	char *needle_lower;
	int len_hay,len_need;
	int t;
	char *loc;
	len_hay = strlen(haystack);
	len_need= strlen(needle);
	hay_lower = (char *) malloc (len_hay +1);
	needle_lower=(char*) malloc (len_need+1);
	for(t=0;t<len_hay;t++)
		hay_lower[t] = tolower(haystack[t]);
	hay_lower[t] = 0;
	for(t=0;t<len_need;t++)
			needle_lower[t] = tolower(needle[t]);
	needle_lower[t] =0;
	loc = strstr(hay_lower,needle_lower);
	free(hay_lower);
	free(needle_lower);
	if (loc == NULL)
		return NULL;
	return haystack + (loc-hay_lower);
//void postresql_NOTICE_HANDLER(void *arg, const char *message);
char *DATAERRORMESSAGE(char *dString, char *preamble)
	char	*m;
	char	tmp[7000];
	m = (char*) malloc(10000);
	sprintf(m,"%s",preamble);
		sprintf(tmp,"Error with POSTGIS data variable. You specified '%s'.<br>\n", dString);
		strcat(m,tmp);
		sprintf(tmp,"Standard ways of specifiying are : <br>\n(1) 'geometry_column from geometry_table' <br>\n(2) 'geometry_column from (&lt;sub query&gt;) as foo using unique &lt;column name&gt; using SRID=&lt;srid#&gt;' <br><br>\n\n");
		strcat(m,tmp);
		sprintf(tmp,"Make sure you put in the 'using unique  &lt;column name&gt;' and 'using SRID=#' clauses in.\n\n<br><br>");
		strcat(m,tmp);
		sprintf(tmp,"For more help, please see http://postgis.refractions.net/documentation.php \n\n<br><br>");
		strcat(m,tmp);
		sprintf(tmp,"Mappostgis.c - version of April 14/2003.\n");
		strcat(m,tmp);
//printf("%s",m);
//printf("size = %i\n",strlen(m));
	return m;
int msPOSTGISLayerParseData(char *data, char *geom_column_name,
					char *table_name, char *urid_name,char *user_srid);
static int gBYTE_ORDER = 0;
//open up a connection to the postgresql database using the connection string in layer->connection
// ie. "host=192.168.50.3 user=postgres port=5555 dbname=mapserv"
int msPOSTGISLayerOpen(layerObj *layer)
	msPOSTGISLayerInfo	*layerinfo;
        int			order_test = 1;
//fprintf(stderr,"msPOSTGISLayerOpen called\n");
	if (layer->postgislayerinfo)
		return MS_SUCCESS;	//already open
        if( layer->data == NULL )
            msSetError(MS_QUERYERR,
					DATAERRORMESSAGE("","Error parsing POSTGIS data variable: nothing specified in DATA statement.<br><br>\n\nMore Help:<br><br>\n\n"),
					"msPOSTGISLayerOpen()");
            return(MS_FAILURE);
	//have to setup a connection to the database
	layerinfo = (msPOSTGISLayerInfo *) malloc( sizeof(msPOSTGISLayerInfo) );
	layerinfo->sql = NULL; //calc later
	layerinfo->row_num=0;
	layerinfo->query_result= NULL;
	layerinfo->conn = PQconnectdb( layer->connection );
    if (PQstatus(layerinfo->conn) == CONNECTION_BAD)
        msSetError(MS_QUERYERR, "couldnt make connection to DB with connect string '%s'.\n<br>\nError reported was '%s'.\n<br>\n\nThis error occured when trying to make a connection to the specified postgresql server.  \n<br>\nMost commonly this is caused by <br>\n(1) incorrect connection string <br>\n(2) you didnt specify a 'user=...' in your connection string <br>\n(3) the postmaster (postgresql server) isnt running <br>\n(4) you are not allowing TCP/IP connection to the postmaster <br>\n(5) your postmaster is not running on the correct port - if its not on 5432 you must specify a 'port=...' <br>\n (6) the security on your system does not allow the webserver (usually user 'nobody') to make socket connections to the postmaster <br>\n(7) you forgot to specify a 'host=...' if the postmaster is on a different machine<br>\n(8) you made a typo <br>\n  ",
                 "msPOSTGISLayerOpen()", layer->connection,PQerrorMessage(layerinfo->conn) );
	  free(layerinfo);
	  return(MS_FAILURE);
//	PQsetNoticeProcessor(layerinfo->conn, postresql_NOTICE_HANDLER ,(void *) layerinfo);
	layer->postgislayerinfo = (void *) layerinfo;
        if( ((char *) &order_test)[0] == 1 )
            gBYTE_ORDER = LITTLE_ENDIAN;
        else
            gBYTE_ORDER = BIG_ENDIAN;
	return MS_SUCCESS;
// Free the itemindexes array in a layer.
void    msPOSTGISLayerFreeItemInfo(layerObj *layer)
//fprintf(stderr,"msPOSTGISLayerFreeItemInfo called\n");
 	if (layer->iteminfo)
      	free(layer->iteminfo);
  	layer->iteminfo = NULL;
//allocate the iteminfo index array - same order as the item list
int msPOSTGISLayerInitItemInfo(layerObj *layer)
	int   i;
	int *itemindexes ;
//fprintf(stderr,"msPOSTGISLayerInitItemInfo called\n");
	if (layer->numitems == 0)
      	return MS_SUCCESS;
 	if((layer->iteminfo = (int *)malloc(sizeof(int)*layer->numitems))== NULL)
   		msSetError(MS_MEMERR, NULL, "msPOSTGISLayerInitItemInfo()");
   	 	return(MS_FAILURE);
	itemindexes = (int*)layer->iteminfo;
  	for(i=0;i<layer->numitems;i++)
		itemindexes[i] = i; //last one is always the geometry one - the rest are non-geom
 	return(MS_SUCCESS);
//Since we now have PostGIST 0.5, and 0.6  calling conventions,
// we have to attempt to handle the database in several ways.  If we do the wrong
// thing, then it'll throw an error and we can rollback and try again.
// 2. attempt to do 0.6 calling convention (spatial ref system needed)
// 3. attempt to do 0.5 calling convention (no spatial ref system)
// The difference between 0.5 and 0.6 is that the bounding box must be
// declared to be in the same the same spatial reference system as the
// geometry column.  For 0.6, we determine the SRID of the column and then
// tag the bounding box as the same SRID.
int prep_DB(char	*geom_table,char  *geom_column,layerObj *layer, PGresult **sql_results,rectObj rect,char *query_string, char *urid_name, char *user_srid)
	PGresult	*result;
	char	columns_wanted[5000];
	char	temp[5000];
	char	tmp[5000];
	char	tmp2[5000];
	char	query_string_0_6[6000];
	int	t;
	char	box3d[200];
	char *pos_from, *pos_ftab, *pos_space, *pos_paren;
	char f_table_name[5000];
	layerinfo = (msPOSTGISLayerInfo *) layer->postgislayerinfo;
	/* Set the urid name */
	layerinfo->urid_name = urid_name;
	/* Extract the proper f_table_name from the geom_table string.
	 * We are expecting the geom_table to be either a single word
	 * or a sub-select clause that possibly includes a join --
	 * (select column[,column[,...]] from ftab[ natural join table2]) as foo
	 * We are expecting whitespace or a ')' after the ftab name.
	pos_from = strstr(geom_table, " from ");
	if (pos_from ==NULL)
		pos_from = strstr(geom_table, " FROM "); //try uppercase
	if (pos_from == NULL) {
		strcpy(f_table_name, geom_table);
	else { // geom_table is a sub-select clause
		pos_ftab = pos_from + 6; // This should be the start of the ftab name
		pos_space = strstr(pos_ftab, " "); // First space
		//pos_paren = strstr(pos_ftab, ")"); // Closing paren of clause
		pos_paren = rindex(pos_ftab,')');
		if (  (pos_space ==NULL)  || (pos_paren ==NULL) ) {
								DATAERRORMESSAGE(geom_table,"Error parsing POSTGIS data variable: Something is wrong with your subselect statement.<br><br>\n\nMore Help:<br><br>\n\n"),
					"prep_DB()");
			return(MS_FAILURE);
		if (pos_paren < pos_space) { // closing parenthesis preceeds any space
			strncpy(f_table_name, pos_ftab, pos_paren - pos_ftab);
		else {
			strncpy(f_table_name, pos_ftab, pos_space - pos_ftab);
	if (layer->numitems ==0)
		if (gBYTE_ORDER == LITTLE_ENDIAN)
			sprintf(columns_wanted,"asbinary(force_collection(force_2d(%s)),'NDR'),%s::text", geom_column, urid_name);
		else
			sprintf(columns_wanted,"asbinary(force_collection(force_2d(%s)),'XDR'),%s::text", geom_column, urid_name);
	else
		columns_wanted[0] = 0; //len=0
		for (t=0;t<layer->numitems; t++)
			sprintf(temp,"%s::text,",layer->items[t]);
			strcat(columns_wanted,temp);
			sprintf(temp,"asbinary(force_collection(force_2d(%s)),'NDR'),%s::text", geom_column, urid_name);
		else
			sprintf(temp,"asbinary(force_collection(force_2d(%s)),'XDR'),%s::text", geom_column, urid_name);
	sprintf(box3d,"'BOX3D(%.15g %.15g,%.15g %.15g)'::BOX3D",rect.minx, rect.miny, rect.maxx, rect.maxy);
	// substitute token '!BOX!' in geom_table with the box3d - do at most 1 substitution
		if (strstr(geom_table,"!BOX!"))
				// need to do a substition
				char	*start, *end;
				char	*result;
				result = malloc(7000);
				start = strstr(geom_table,"!BOX!");
				end = start+5;
				start[0] =0;
				result[0]=0;
				strcat(result,geom_table);
				strcat(result,box3d);
				strcat(result,end);
				geom_table= result;
	if (layer->filter.string == NULL)
		if (strlen(user_srid) == 0)
			sprintf(query_string_0_6,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE %s && setSRID(%s, find_srid('','%s','%s') )",
						columns_wanted,geom_table,geom_column,box3d,removeWhite(f_table_name),removeWhite(geom_column));
		else	//use the user specified version
			sprintf(query_string_0_6,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE %s && setSRID(%s, %s )",
						columns_wanted,geom_table,geom_column,box3d,user_srid);
	else
			sprintf(query_string_0_6,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE (%s) and (%s && setSRID( %s,find_srid('','%s','%s') ))",
						columns_wanted,geom_table,layer->filter.string,geom_column,box3d,removeWhite(f_table_name),removeWhite(geom_column));
		else
			sprintf(query_string_0_6,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE (%s) and (%s && setSRID( %s,%s) )",
						columns_wanted,geom_table,layer->filter.string,geom_column,box3d,user_srid);
	//start transaction required by cursor
    result = PQexec(layerinfo->conn, "BEGIN");
    if (!(result) || PQresultStatus(result) != PGRES_COMMAND_OK)
	      msSetError(MS_QUERYERR, "Error executing POSTGIS  BEGIN   statement.",
                 "msPOSTGISLayerWhichShapes()");
        	PQclear(result);
	  	layerinfo->query_result = NULL;
		return(MS_FAILURE);		// totally screwed
    PQclear(result);
	//set enable_seqscan=off not required (already done)
//fprintf (stderr,"query_string_0_6:%s\n",query_string_0_6);
    result = PQexec(layerinfo->conn, query_string_0_6 );
    if ( (result!=NULL) && (PQresultStatus(result) == PGRES_COMMAND_OK) )
	   	//PQclear(result);
		*sql_results = result;
		strcpy(query_string, query_string_0_6 );
 		return (MS_SUCCESS);
	//okay, that command didnt work.  Its probably a 0.5 database
	// We have to everything again, after performing a rollback.
	 PQclear(result);
       result = PQexec(layerinfo->conn, "rollback" );
	 PQclear(result);
	 result = PQexec(layerinfo->conn, "begin" );
	      msSetError(MS_QUERYERR, "Couldnt recover from a bad query: \n'%s'\n",
                 "prep_DB()",query_string_0_6);
        	PQclear(result);
    PQclear(result);
//fprintf (stderr,"prep_DB:query_string_0_5:%s\n",query_string_0_5);
		sprintf(tmp2, "Error executing POSTGIS  DECLARE (the actual query) statement: '%s' <br><br>\n\nPostgresql reports the error '%s'<br><br>\n\nMore Help:<br><br>\n\n",
				query_string_0_6,
		sprintf(tmp, "%s%s",
					tmp2,
					DATAERRORMESSAGE("&lt;check your .map file&gt;" ,"")
        msSetError(MS_QUERYERR,tmp,"prep_DB()");
        PQclear(result);
// build the neccessary SQL
// allocate a cursor for the SQL query
// get ready to read from the cursor
// For queries, we need to also retreive the OID for each of the rows
// So GetShape() can randomly access a row.
int msPOSTGISLayerWhichShapes(layerObj *layer, rectObj rect)
	char	*query_str;
	char	*table_name;
	char	*geom_column_name;
	char	*urid_name;
	char	*user_srid;
	int	set_up_result;
	table_name = malloc(500);
	geom_column_name = malloc(500);
	urid_name = malloc(500);
	user_srid = malloc(500);
//fprintf(stderr,"msPOSTGISLayerWhichShapes called\n");
	if (layerinfo == NULL)
		//layer not opened yet
		msSetError(MS_QUERYERR, "msPOSTGISLayerWhichShapes called on unopened layer (layerinfo = NULL)",
		return(MS_FAILURE);
                       "Missing DATA clause in PostGIS Layer definition.  DATA statement must contain 'geometry_column from table_name' or 'geometry_column from (sub-query) as foo'.",
            return(MS_FAILURE);
	query_str = (char *) malloc(6000); //should be big enough
	memset(query_str,0,6000);		//zero it out
	msPOSTGISLayerParseData(layer->data, geom_column_name, table_name, urid_name,user_srid);
	set_up_result= prep_DB(table_name,geom_column_name, layer, &(layerinfo->query_result), rect,query_str, urid_name,user_srid);
	if (set_up_result != MS_SUCCESS)
		return set_up_result; //relay error
	layerinfo->sql = query_str;
    layerinfo->query_result = PQexec(layerinfo->conn, "FETCH ALL in mycursor");
    if (!(layerinfo->query_result) || PQresultStatus(layerinfo->query_result) !=  PGRES_TUPLES_OK)
		char tmp[4000];
		sprintf(tmp, "Error executing POSTGIS  SQL   statement (in FETCH ALL): %s\n-%s\n", query_str,PQerrorMessage(layerinfo->conn) );
				 	DATAERRORMESSAGE("",tmp),
        	PQclear(layerinfo->query_result);
		return(MS_FAILURE);
	layerinfo->row_num =0;
    return(MS_SUCCESS);
// Close the postgis record set and connection
int msPOSTGISLayerClose(layerObj *layer)
//fprintf(stderr,"msPOSTGISLayerClose called\n");
	if (layerinfo != NULL)
			PQfinish(layerinfo->conn);
			layerinfo->conn = NULL;
		free(layerinfo);
		layer->postgislayerinfo = NULL;
	return(MS_SUCCESS);
// wkb is assumed to be 2d (force_2d)
// and wkb is a GEOMETRYCOLLECTION (force_collection)
// and wkb is in the endian of this computer (asbinary(...,'[XN]DR'))
// each of the sub-geom inside the collection are point,linestring, or polygon
// also, int is 32bits long
//       double is 64bits long
// convert the wkb into points
//	points -> pass through
//	lines->   constituent points
//	polys->   treat ring like line and pull out the consituent points
int	force_to_points(char	*wkb, shapeObj *shape)
	//we're going to make a 'line' for each entity (point, line or ring) in the geom collection
	int offset =0,pt_offset;
	int ngeoms ;
	int	t,u,v;
	int	type,nrings,npoints;
	lineObj	line={0,NULL};
	shape->type = MS_SHAPE_NULL;  //nothing in it
	memcpy( &ngeoms, &wkb[5], 4);
	offset = 9;  //were the first geometry is
	for (t=0; t<ngeoms; t++)
		memcpy( &type, &wkb[offset+1], 4);  // type of this geometry
		if (type ==1)	//POINT
			shape->type = MS_SHAPE_POINT;
			line.numpoints = 1;
			line.point = (pointObj *) malloc (sizeof(pointObj));
				memcpy( &line.point[0].x , &wkb[offset+5  ], 8);
				memcpy( &line.point[0].y , &wkb[offset+5+8], 8);
			offset += 5+16;
			msAddLine(shape,&line);
			free(line.point);
		if (type == 2) //linestring
			memcpy(&line.numpoints, &wkb[offset+5],4); //num points
			line.point = (pointObj *) malloc (sizeof(pointObj)* line.numpoints ); //point struct
			for(u=0;u<line.numpoints ; u++)
				memcpy( &line.point[u].x , &wkb[offset+9 + (16 * u)], 8);
				memcpy( &line.point[u].y , &wkb[offset+9 + (16 * u)+8], 8);
			offset += 9 +(16)*line.numpoints;  //length of object
			free(line.point);
		if (type == 3) //polygon
			memcpy(&nrings, &wkb[offset+5],4); //num rings
			//add a line for each polygon ring
			pt_offset = 0;
			offset += 9; //now points at 1st linear ring
			for (u=0;u<nrings;u++)	//for each ring, make a line
				memcpy(&npoints, &wkb[offset],4); //num points
				line.numpoints = npoints;
				line.point = (pointObj *) malloc (sizeof(pointObj)* npoints); //point struct
				for(v=0;v<npoints;v++)
					memcpy( &line.point[v].x , &wkb[offset+4 + (16 * v)], 8);
					memcpy( &line.point[v].y , &wkb[offset+4 + (16 * v)+8], 8);
				//make offset point to next linear ring
				free(line.point);
				offset += 4+ (16)*npoints;
	return(MS_SUCCESS);
//convert the wkb into lines
//  points-> remove
//  lines -> pass through
//  polys -> treat rings as lines
int	force_to_lines(char	*wkb, shapeObj *shape)
	int ngeoms ;
	int	t,u,v;
		//cannot do anything with a point
			shape->type = MS_SHAPE_LINE;
			free(line.point);
			pt_offset = 0;
				free(line.point);
	return(MS_SUCCESS);
// point   -> reject
// line    -> reject
// polygon -> lines of linear rings
int	force_to_polygons(char	*wkb, shapeObj *shape)
	int ngeoms ;
	int	t,u,v;
			shape->type = MS_SHAPE_POLYGON;
			pt_offset = 0;
				free(line.point);
	return(MS_SUCCESS);
// if there is any polygon in wkb, return force_polygon
// if there is any line in wkb, return force_line
// otherwise return force_point
int	dont_force(char	*wkb, shapeObj *shape)
	int offset =0;
	int ngeoms ;
	int	type,t;
	int		best_type;
//printf("dont force");
	best_type = MS_SHAPE_NULL;  //nothing in it
			best_type = MS_SHAPE_POLYGON;
		if ( (type ==2) && ( best_type != MS_SHAPE_POLYGON) )
			best_type = MS_SHAPE_LINE;
		if (   (type==1) && (best_type == MS_SHAPE_NULL) )
			best_type = MS_SHAPE_POINT;
	if (best_type == MS_SHAPE_POINT)
		return force_to_points(wkb,shape);
	if (best_type == MS_SHAPE_LINE)
		return force_to_lines(wkb,shape);
	if (best_type == MS_SHAPE_POLYGON)
		return force_to_polygons(wkb,shape);
	return(MS_FAILURE); //unknown type
//find the bounds of the shape
void find_bounds(shapeObj *shape)
	int t,u;
	int first_one = 1;
	for (t=0; t< shape->numlines; t++)
		for(u=0;u<shape->line[t].numpoints; u++)
			if (first_one)
				shape->bounds.minx = shape->line[t].point[u].x;
				shape->bounds.maxx = shape->line[t].point[u].x;
				shape->bounds.miny = shape->line[t].point[u].y;
				shape->bounds.maxy = shape->line[t].point[u].y;
				first_one = 0;
			else
				if (shape->line[t].point[u].x < shape->bounds.minx)
				if (shape->line[t].point[u].x > shape->bounds.maxx)
				if (shape->line[t].point[u].y < shape->bounds.miny)
				if (shape->line[t].point[u].y > shape->bounds.maxy)
//find the next shape with the appropriate shape type (convert it if necessary)
// also, load in the attribute data
//MS_DONE => no more data
int msPOSTGISLayerNextShape(layerObj *layer, shapeObj *shape)
	int	result;
//fprintf(stderr,"msPOSTGISLayerNextShape called\n");
        	msSetError(MS_QUERYERR, "NextShape called with layerinfo = NULL",
                 "msPOSTGISLayerNextShape()");
		return(MS_FAILURE);
	result= msPOSTGISLayerGetShapeRandom(layer, shape, &(layerinfo->row_num)   );
	// getshaperandom will increment the row_num
	//layerinfo->row_num   ++;
	return result;
//Used by NextShape() to access a shape in the query set
// TODO: only fetch 1000 rows at a time.  This should check to see if the
//       requested feature is in the set.  If it is, return it, otherwise
// 	   grab the next 1000 rows.
int msPOSTGISLayerGetShapeRandom(layerObj *layer, shapeObj *shape, long *record)
	char				*wkb;
	int				result,t,size;
	char				*temp,*temp2;
	long				record_oid;
//fprintf(stderr,"msPOSTGISLayerGetShapeRandom : called row %li\n",record);
        	msSetError(MS_QUERYERR, "GetShape called with layerinfo = NULL",
                 "msPOSTGISLayerGetShape()");
		return(MS_FAILURE);
	if (layerinfo->conn == NULL)
        	msSetError(MS_QUERYERR, "NextShape called on POSTGIS layer with no connection to DB.",
		return(MS_FAILURE);
	if (layerinfo->query_result == NULL)
        	msSetError(MS_QUERYERR, "GetShape called on POSTGIS layer with invalid DB query results.",
                 "msPOSTGISLayerGetShapeRandom()");
		return(MS_FAILURE);
	while(shape->type == MS_SHAPE_NULL)
		if (  (*record) < PQntuples(layerinfo->query_result) )
			//retreive an item
			wkb = (char *) PQgetvalue(layerinfo->query_result, (*record), layer->numitems);
			switch(layer->type)
				case MS_LAYER_POINT:
					result = force_to_points(wkb, shape);
					break;
				case MS_LAYER_LINE:
					result = force_to_lines(wkb, shape);
					break;
				case MS_LAYER_POLYGON:
					result = 	force_to_polygons(wkb, shape);
					break;
				case MS_LAYER_ANNOTATION:
				case MS_LAYER_QUERY:
					result = dont_force(wkb,shape);
					break;
                case MS_LAYER_RASTER:
                                        msDebug( "Ignoring MS_LAYER_RASTER in mappostgis.c\n" );
                                        break;
                case MS_LAYER_CIRCLE:
                                        break;
			if (shape->type != MS_SHAPE_NULL)
				//have to retreive the attributes
			        shape->values = (char **) malloc(sizeof(char *) * layer->numitems);
				for (t=0;t<layer->numitems;t++)
					 temp = (char *) PQgetvalue(layerinfo->query_result, (*record), t);
					 size = PQgetlength(layerinfo->query_result,(*record), t ) ;
					 temp2 = (char *) malloc(size+1 );
					 memcpy(temp2, temp, size);
					 temp2[size] = 0; //null terminate it
					 shape->values[t] = temp2;
				temp = (char *) PQgetvalue(layerinfo->query_result, (*record), t+1); // t is WKB, t+1 is OID
				record_oid = strtol (temp,NULL,10);
				shape->index = record_oid;
				shape->numvalues = layer->numitems;
				find_bounds(shape);
				(*record)++; 		//move to next shape
			else
		else
			return (MS_DONE);
	msFreeShape(shape);
	return(MS_FAILURE);
// Execute a query on the DB based on record being an OID.
int msPOSTGISLayerGetShape(layerObj *layer, shapeObj *shape, long record)
	char	*query_str;
	char	table_name[5000];
	char	geom_column_name[5000];
	char	urid_name[5000];
	char	user_srid[5000];
	//int	nitems;
	char	temp[5000];
	char				*wkb;
	int				result,t,size;
	char				*temp1,*temp2;
//fprintf(stderr,"msPOSTGISLayerGetShape called for record = %i\n",record);
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetShape called on unopened layer (layerinfo = NULL)",
		return(MS_FAILURE);
	if (layer->numitems ==0) //dont need the oid since its really record
			sprintf(columns_wanted,"asbinary(force_collection(force_2d(%s)),'NDR')", geom_column_name);
		else
			sprintf(columns_wanted,"asbinary(force_collection(force_2d(%s)),'XDR')", geom_column_name);
	else
			sprintf(temp,"asbinary(force_collection(force_2d(%s)),'NDR')", geom_column_name);
		else
			sprintf(temp,"asbinary(force_collection(force_2d(%s)),'XDR')", geom_column_name);
		sprintf(query_str,"DECLARE mycursor BINARY CURSOR FOR SELECT %s from %s WHERE %s = %li", columns_wanted,table_name,urid_name,record);
//fprintf(stderr,"msPOSTGISLayerGetShape: %s \n",query_str);
    query_result = PQexec(layerinfo->conn, "BEGIN");
    if (!(query_result) || PQresultStatus(query_result) != PGRES_COMMAND_OK)
        	PQclear(query_result);
		return(MS_FAILURE);
    query_result = PQexec(layerinfo->conn, "set enable_seqscan = off");
	      msSetError(MS_QUERYERR, "Error executing POSTGIS  'set enable_seqscan off'   statement.",
		return(MS_FAILURE);
    query_result = PQexec(layerinfo->conn, query_str );
		char tmp[4000];
		sprintf(tmp, "Error executing POSTGIS  SQL   statement (in FETCH ALL): %s\n-%s\n<br>More Help:<br>", query_str,PQerrorMessage(layerinfo->conn) );
		return(MS_FAILURE);
    if (!(query_result) || PQresultStatus(query_result) !=  PGRES_TUPLES_OK)
		char tmp[4000];
		return(MS_FAILURE);
			//query has been done, so we can retreive the results
		if (  0 < PQntuples(query_result) )  //only need to get one shape
			//retreive an item
			wkb = (char *) PQgetvalue(query_result, 0, layer->numitems);  // layer->numitems is the wkt column
			switch(layer->type)
					break;
				case MS_LAYER_LINE:
					break;
					break;
					break;
                                        break;
//fprintf(stderr,"msPOSTGISLayerGetShape: finding attribute info for '%s'\n",layer->items[t]);
					 temp1= (char *) PQgetvalue(query_result, 0, t);
					 size = PQgetlength(query_result,0, t ) ;
					 memcpy(temp2, temp1, size);
//fprintf(stderr,"msPOSTGISLayerGetShape: shape->values[%i] has value '%s'\n",t,shape->values[t]);
				shape->index = record;
				find_bounds(shape);
		else
			return (MS_DONE);
	msFreeShape(shape);
	return(MS_FAILURE);
//query the DB for info about the requested table
// CHEAT: dont look in the system tables, get query optimization infomation
// get the table name, return a list of the possible columns (except GEOMETRY column)
// found out this is called during a query
int msPOSTGISLayerGetItems(layerObj *layer)
	char				sql[6000];
	//int				nitems;
	int		t;
	char	*col;
	char found_geom = 0;
	int item_num;
//fprintf(stderr, "in msPOSTGISLayerGetItems  (find column names)\n");
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetItems called on unopened layer",
                 "msPOSTGISLayerGetItems()");
		return(MS_FAILURE);
        	msSetError(MS_QUERYERR, "msPOSTGISLayerGetItems called on POSTGIS layer with no connection to DB.",
		return(MS_FAILURE);
	//get the table name and geometry column name
	msPOSTGISLayerParseData(layer->data, geom_column_name, table_name, urid_name, user_srid);
	// two cases here.  One, its a table (use select * from table) otherwise, just use the select clause
	sprintf(sql,"SELECT * FROM %s LIMIT 0",table_name); // attempt the query, but dont actually do much (this might take some time if there is an order by!)
	query_result = PQexec(layerinfo->conn, sql );
		char tmp[4000];
				sprintf(tmp, "Error executing POSTGIS  SQL   statement (in msPOSTGISLayerGetItems): %s\n-%s\n", sql,PQerrorMessage(layerinfo->conn) );
		return(MS_FAILURE);
	layer->numitems = PQnfields(query_result)-1; //dont include the geometry column
	layer->items = malloc (sizeof(char *) * (layer->numitems+1) ); // +1 incase there is a problem finding goeometry column
																// it will return an error if there is no geometry column found,
																// so this isnt a problem
		found_geom = 0; //havent found the geom field
		item_num = 0;
	for (t=0;t<PQnfields(query_result);t++)
		col = PQfname(query_result,t);
		if (strcmp(col, geom_column_name) != 0) // this isnt the geometry column
			layer->items[item_num] = (char*)malloc(strlen(col)+1);
			strcpy(layer->items[item_num], col);
			item_num++;
		else
			found_geom = 1;
	if (!(found_geom))
		char tmp[4000];
		sprintf(tmp, "msPOSTGISLayerGetItems: tried to find the geometry column in the results from the database, but couldnt find it.  Is it miss-capitialized? '%s'", geom_column_name );
				 	tmp,
		return(MS_FAILURE);
	return msPOSTGISLayerInitItemInfo(layer);
//we return an infinite extent
// we could call the SQL AGGREGATE extent(GEOMETRY), but that would take FOREVER
// to return (it has to read the entire table).
// So, we just tell it that we're everywhere and lets the spatial indexing figure things out for us
// Never seen this function actually called
int msPOSTGISLayerGetExtent(layerObj *layer, rectObj *extent)
//fprintf(stderr,"msPOSTGISLayerGetExtent called\n");
	extent->minx = extent->miny =  -1.0*FLT_MAX ;
	extent->maxx = extent->maxy =  FLT_MAX;
	return(MS_SUCCESS);
		//this should get the real extents,but it requires a table read
		// unforunately, there is no way to call this function from mapscript, so its
		// pretty useless.  Untested since you cannot actually call it.
	char		sql[5000];
	if (layer == NULL)
				char tmp[5000];
				sprintf(tmp, "layer is null - have you opened the layer yet?");
		        	msSetError(MS_QUERYERR, tmp,
		                 "msPOSTGISLayerGetExtent()");
		return(MS_FAILURE);
   msPOSTGISLayerParseData(layer->data, geom_column_name,table_name, urid_name,user_srid);
   sprintf(sql,"select extent(%s) from %s", geom_column_name,table_name);
				char tmp[5000];
				sprintf(tmp, "layer doesnt have a postgis connection - have you opened the layer yet?");
		return(MS_FAILURE);
  	query_result = PQexec(layerinfo->conn, sql);
		char tmp[5000];
		sprintf(tmp, "Error executing POSTGIS  SQL   statement (in msPOSTGISLayerGetExtent): %s", layerinfo->sql);
		return(MS_FAILURE);
	if (PQntuples(query_result) != 1)
				char tmp[5000];
				sprintf(tmp, "Error executing POSTGIS  SQL   statement (in msPOSTGISLayerGetExtent) [doesnt have exactly 1 result]: %s", layerinfo->sql);
		return(MS_FAILURE);
	sscanf(PQgetvalue(query_result,0,0),"%lf %lf %lf %lf", &extent->minx,&extent->miny,&extent->maxx,&extent->maxy );
/* Function to parse the Mapserver DATA parameter for geometry
 * column name, table name and name of a column to serve as a
 * unique record id
	char *pos_opt, *pos_scn, *tmp, *pos_srid;
	int 	slength;
	/* given a string of the from 'geom from ctivalues' or 'geom from () as foo'
	 * return geom_column_name as 'geom'
	 * and table name as 'ctivalues' or 'geom from () as foo'
	/* First look for the optional ' using unique ID' string */
	pos_opt = strstrIgnoreCase(data, " using unique ");
	if (pos_opt == NULL) {
		/* No user specified unique id so we will use the Postgesql OID */
		strcpy(urid_name, "OID");
	else {
		// CHANGE - protect the trailing edge for thing like 'using unique ftab_id using srid=33'
		tmp = strstr(pos_opt + 14," ");
		if (tmp == NULL) //it lookes like 'using unique ftab_id'
			strcpy(urid_name, pos_opt + 14);
		else
			//looks like ' using unique ftab_id ' (space at end)
			strncpy(urid_name, pos_opt + 14, tmp-(pos_opt + 14  ) );
			urid_name[tmp-(pos_opt + 14)] = 0; // null terminate it
	pos_srid = strstrIgnoreCase(data," using SRID=");
	if (pos_srid == NULL)
		user_srid[0] = 0; // = ""
	else
		//find the srid
		slength=strspn(pos_srid+12,"-0123456789");
		if (slength == 0)
					DATAERRORMESSAGE(data,"Error parsing POSTGIS data variable: You specified 'using SRID=#' but didnt have any numbers!<br><br>\n\nMore Help:<br><br>\n\n"),
					"msPOSTGISLayerParseData()");
			return(MS_FAILURE);
		else
			strncpy(user_srid,pos_srid+12,slength);
			user_srid[slength] = 0; // null terminate it
	// this is a little hack so the rest of the code works.  If the ' using SRID=' comes before
	// the ' using unique ', then make sure pos_opt points to where the ' using SRID' starts!
		pos_opt = pos_srid;
	else
		if (pos_srid != NULL)
			if (pos_opt>pos_srid)
				pos_opt = pos_srid;
	/* Scan for the table or sub-select clause */
	pos_scn = strstr(data, " from ");
	if (pos_scn == NULL) {
					DATAERRORMESSAGE(data,"Error parsing POSTGIS data variable.  Must contain 'geometry_column from table_name' or 'geom from (subselect) as foo' (couldnt find ' from ').  More help: <br><br>\n\n"),
		//msSetError(MS_QUERYERR, "Error parsing POSTGIS data variable.  Must contain 'geometry_column from table_name' or 'geom from (subselect) as foo' (couldnt find ' from ').", "msPOSTGISLayerParseData()");
		return(MS_FAILURE);
	/* Copy the geometry column name */
	memcpy(geom_column_name, data, (pos_scn)-(data));
	geom_column_name[(pos_scn)-(data)] = 0; //null terminate it
	/* Copy out the table name or sub-select clause */
		strcpy(table_name, pos_scn + 6);	//table name or sub-select clause
	else {
		strncpy(table_name, pos_scn + 6, (pos_opt) - (pos_scn + 6));
		table_name[(pos_opt) - (pos_scn + 6)] = 0; //null terminate it
	if ( (strlen(table_name) < 1 ) ||  (strlen(geom_column_name) < 1 ) ) {
					DATAERRORMESSAGE(data,"Error parsing POSTGIS data variable.  Must contain 'geometry_column from table_name' or 'geom from (subselect) as foo' (couldnt find a geometry_column or table/subselect).  More help: <br><br>\n\n"),
		return(MS_FAILURE);
//printf("msPOSTGISLayerParseData: unique column = %s, srid='%s', geom_column_name = %s, table_name=%s\n", urid_name,user_srid,geom_column_name,table_name);
	return(MS_SUCCESS);
#else
//prototypes if postgis isnt supposed to be compiled
		msSetError(MS_QUERYERR, "msPOSTGISLayerOpen called but unimplemented!  (mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerFreeItemInfo called but unimplemented!(mapserver not compiled with postgis support)",
                 "msPOSTGISLayerFreeItemInfo()");
		msSetError(MS_QUERYERR, "msPOSTGISLayerInitItemInfo called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerWhichShapes called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerClose called but unimplemented!(mapserver not compiled with postgis support)",
                 "msPOSTGISLayerClose()");
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerNextShape called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetShape called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetExtent called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetShapeRandom called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
		msSetError(MS_QUERYERR, "msPOSTGISLayerGetItems called but unimplemented!(mapserver not compiled with postgis support)",
		return(MS_FAILURE);
// end above's #ifdef USE_POSTGIS
#endif
--------------010709050900000403030207--
