[Mapserver-users] generating world files
Thorsten Fischer thfischer at mapmedia.de
Wed Apr 16 10:54:16 EDT 2003
Heiko,
> i`m wondering if it is possiple to generate a .tfw file for a rendered
> map in mapserver,
> maybe like:
> $tfw = $map->getworldfile();
This is fairly easy to do.  A worldfile consists of 6 lines of ascii:
[width of a pixel in map coordinates]
[a rotation factor] <- you can most likely skip this
[another rotation factor] <- same
[height of a pixel in map coordinates]
[x of upper left corner of the image]
[y of upper left corner of the image]
That's all. You can get parameters 5 and 6 from your current image
extent, fill in the rotation parameters with 0.00000 most likely, and
then calculate parameters 1 and 4 yourself. Hint: first parameter is
(maxx - minx) / (width of map in pixels).
hth,
thorsten
