[Mapserver-users] Perl MapScript (3.7)
Lowell Filak
lfilak at medinaco.org
Wed Apr 16 09:01:54 EDT 2003
I don't know for certain, however I think this is just a matter of downloading a newer nightly build and recompiling.
The mapscript module does not appear to contain any .al-files/autosplitting so possibly there was a spelling mismatch in mapscipt.pm, I don't readily see a problem in the current nightly build.
Possibly someone else with the 3-14 build can verify that autosplit was/wasn't used.?
HTH
Lowell F.
The following message was sent by Babak Toloue Tehrani <babak.tehrani at geosysnet.de> on 16 Apr 2003 14:51:01 +0200.
> Hello,
> I am new to MapScript and try to get an output. I use Suse Linux 8.1
> with Mapserver 3.7_dev (2003-03-14). Everithing is working fine:
> /srv/www/cgi-bin/mapserv -v
> MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=GD2_RGB INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Perl MapScript compiles also without an error.
> # make install
> Installing
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/mapscript.bs
> Installing
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/mapscript.so
> Files found in blib/arch: installing files in blib/lib into architecture
> dependent library tree
> Installing
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/mapscript.pm
> Writing
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/.packlist
> Appending installation info to
> /usr/lib/perl5/5.8.0/i586-linux-thread-multi/perllocal.pod
> I tried to write my first Perl Mapscript an run it with: perl demo.pl
> and get following error:
> Can't locate auto/mapscript/mapObj/selectOutpu.al in @INC (@INC
> contains: /usr/lib/perl5/5.8.0/i586-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl .) at demo.pl
> line 7
> #!/usr/bin/perl -w
> use strict;
> use mapscript;
> my $map = new mapscript::mapObj('brd_demo_geo.map') or die('Unable to
> openmapfile.');
> $map->selectOutputFormat("PNG");
> $map->draw() or die('Unable to draw map');
> my $img->saveImage();
> # Start of map file
> NAME BRD-DEMO
> STATUS ON
> SIZE 600 500
> EXTENT 5.3 55.5 15.5 46.9
> UNITS METERS
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE brd_demo_geo.html
> IMAGEPATH "set in brd_demo_geo_ini.html"
> IMAGEURL "set in brd_demo_geo_ini.html"
> END
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> END
> QUERYMAP
> STATUS OFF
> SIZE -1 -1
> COLOR 255 255 0
> STYLE HILITE
> END
> LAYER
> NAME brd
> TYPE POLYGON
> STATUS DEFAULT
> DATA lnd01dd.shp
> CLASS
> NAME "brd"
> SYMBOL 0
> COLOR 195 195 195
> OUTLINECOLOR 102 102 102
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> I am also not able to run the examples:
> # perl shpinfo.pl -file=data/brd.shp
> Usage: new_shapefileObj(filename,shapepath,type); at
> /usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/mapscript.pm line
> 701.
> Thanks a lot for helping:
> Babak
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
