[Mapserver-users] how to show big5
Jehng-Jung Kao jjkao at ensys.ev.nctu.edu.tw
Wed Apr 16 21:02:31 EDT 2003
On Thu, 10 Apr 2003, Zhou Xu wrote:
> It depends on how you use it. if you want to convert the strings on-line, please refer to the attached files; If the strings is stored in database, you may use some other utitlities to convert it, for example MS.Notepad and so on.
Thank you for your answer and files.
I actually find the other solution.
For your reference,
  I use "iconv" on RedHat and re-compile php to support iconv.
  Then, the functions provided by iconv can easily convert
  big5 -> utf8.
Jehng-Jung Kao
