[Mapserver-users] linked photos
Lowther, David W
dlowther at ou.edu
Thu Apr 17 10:12:05 EDT 2003
Kevin,
The way I handle this is to put an script in the onload event of the body
tag in the wuery template and jump to a page with the photo based on the
link you created from the attribute data.
Dave
> -----Original Message-----
> From: Kevin Flanders [mailto:kevinflanders at rcn.com]
> Sent: Thursday, April 17, 2003 9:03 AM
> To: Lowther, David W; mapservermailing
> Subject: RE: [Mapserver-users] linked photos
> Thanks David.....yes, I can put the relative path in the
> datasource, but can I simply click on the point feature and
> bring up the photo (or photos) directly?
> Kevin
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
> Lowther, David W
> Sent: Thursday, April 17, 2003 9:14 AM
> To: 'kevin at peoplegis.com'; mapservermailing
> Kevin,
> If you've got attribute information in your datasource that
> gets you to a path to the photo, or if you can generate that
> path from attributes then you can just build a HREF into your
> query template for that layer and then a user can click the
> link to view the photo.
> Dave Lowther
> > Sent: Tuesday, April 15, 2003 2:47 PM
> > To: mapservermailing
> > Subject: [Mapserver-users] linked photos
> > Is there a general explanation somewhere as to how to hotlink and
> > access photos in MapServer using a point shapefile?
> > Kevin
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
