[Mapserver-users] linked photos
Lowther, David W
dlowther at ou.edu
Thu Apr 17 10:22:36 EDT 2003
And I guess it might be important to note that my query results are in a
different frame - otherwise this wouldn't work well..
> -----Original Message-----
> From: Lowther, David W [mailto:dlowther at ou.edu]
> Sent: Thursday, April 17, 2003 9:19 AM
> To: Mapserver-Users (mapserver-users at lists.gis.umn.edu)
> Subject: RE: [Mapserver-users] linked photos
> Kevin,
> The way I handle this is to put an script in the onload event
> of the body tag in the wuery template and jump to a page with
> the photo based on the link you created from the attribute data.
> Dave
> > From: Kevin Flanders [mailto:kevinflanders at rcn.com]
> > Sent: Thursday, April 17, 2003 9:03 AM
> > To: Lowther, David W; mapservermailing
> > Thanks David.....yes, I can put the relative path in the
> datasource,
> > but can I simply click on the point feature and bring up
> the photo (or
> > photos) directly?
> > Kevin
> > From: mapserver-users-admin at lists.gis.umn.edu
> > [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf
> Of Lowther,
> > David W
> > Sent: Thursday, April 17, 2003 9:14 AM
> > To: 'kevin at peoplegis.com'; mapservermailing
> > Kevin,
> > If you've got attribute information in your datasource that
> gets you
> > to a path to the photo, or if you can generate that path from
> > attributes then you can just build a HREF into your query
> template for
> > that layer and then a user can click the link to view the photo.
> > Dave Lowther
> > > Sent: Tuesday, April 15, 2003 2:47 PM
> > > To: mapservermailing
> > > Subject: [Mapserver-users] linked photos
> > > Is there a general explanation somewhere as to how to hotlink and
> > > access photos in MapServer using a point shapefile?
> > > Kevin
> > > _______________________________________________
> > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
