[Mapserver-users] Mr SID & Mapserver
Dylan Keon
keon at nacse.org
Thu Apr 17 14:56:59 EDT 2003
You're probably working on an ext2 partition, which imposes the 2GB file
size limit. If you have disk space you might try creating a separate
partition (or add another disk) and format it as ext3 or reiserfs. I
believe those filesystems both allow file sizes > 2GB, at least when
using a recent 2.4.x kernel. Actually, they may have even fixed that
limitation for ext2 in recent kernels...I'm not sure.
Another option for those of you using Windows is Irfanview, which is a
fantastic little program that supports a large number of image formats,
including MrSID. Be sure to install the plugins. It will allow you to
convert MrSID images to TIFFs as a batch process. You'll need to rename
your world files, but that's about it. This might not work with huge
MrSID files, but I've had success converting 50MB files.
--Dylan
Jim Burnett wrote:
> How do I split my larg Mr Sid file? I cant un-compress it in Linux because
> of the 2 gig limitation.
> So how would I split it ?
> ----- Original Message -----
> From: "Randy James" <rjames57 at yahoo.com>
> To: "Jim Burnett" <r000t at adelphia.net>
> Cc: <Mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, April 17, 2003 2:09 PM
> Subject: Re: [Mapserver-users] Mr SID & Mapserver
>>Hi
>>I have 20 gigs geotiffs broken into 160mb files and than
>>tiled using the gdal tools; to handle large my tif files.
>>But i'm not displaying all the tiles at once just when
>>zooming in (they turn on at 1:150,000) and for query
>>results.
>>Cheers
>>Randy
>>--- Jim Burnett <r000t at adelphia.net> wrote:
>>>Yes but the problem is these Mr Sid files are 3-6gigs
>>>un-compressed into
>>>tiff format. Linux can only handle 2 gig files.
>>>-jim
>>>To: <r000t at adelphia.net>
>>>Sent: Thursday, April 17, 2003 12:31 PM
>>>>Hi
>>>>I have been using the MrSID Viewer(www.landsystems.com,
>>>>Lizardtech) to convert MrSid files to geotiff, than
>>>using
>>>>the tif in mapserver.
>>>>cheers
>>>>Randy
>>>>--- Frank Warmerdam <warmerdam at pobox.com> wrote:
>>>>>Jim Burnett wrote:
>>>>>>Anyone have any ideas on how to integrate Mr SID
>>>with a
>>>>>mapserver or
>>>>>>mapscript application? Any good "on the fly" mr sid
>>>>>converters out there?
>>>>>Jim,
>>>>>I am unaware of any existing method of using MrSID
>>>>>directly with MapServer;
>>>>>however, Andrey Kiselev and I will be implementing
>>>MrSID
>>>>>support in GDAL
>>>>>(used by MapServer) over the coming four weeks. To
>>>use
>>>>>it you would still
>>>>>need to license a MrSID SDK from Lizardtech.
>>>>>Best regards,
s
Dylan Keon
GIS/Database Specialist
Northwest Alliance for Computational
Science and Engineering (NACSE)
Oregon State University
Corvallis, OR 97331
keon at nacse.org (541) 737-6608
