[Mapserver-users] Basic Query Question
woodbri at swoodbridge.com woodbri at swoodbridge.com
Fri Apr 18 19:24:02 EDT 2003
Kieran,
Each layer that you want to be Query-able should have a template.
This is required because each layer can have different attributes
that you might want to display for it when it is queried. So even
though you might have a bunch of point layers, the airport layer may
have different attributes than the shipwreck point layer, vs. the
abandoned mines layer, etc.
When you do a query you query all the layers that are ON or DEFAULT
that also have a template defined for it. No template definition,
then it will not be queried.
Thats about all there is.
-Steve W.
On 18 Apr 2003 at 15:39, Kieran J. Ames wrote:
> List,
> Call it Brain damage, but I can't seem to get a basic concept.
> If I set up different query templates, say one for points and one for
> polylines, how do I define which layer is queried? I want to offer the
> ability to query one of several layers based on user selection, but
> don't know how I specify which one. Thanks, Kieran
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
