[Mapserver-users] (Steve) Real coordinates query
Steve Lime steve.lime at dnr.state.mn.us
Mon Apr 21 13:28:12 EDT 2003
No, I've not fixed this in the CVS. Been out of town the last 10 days
and it will take me
awhile to catch up.
Steve
>>> "Alessandro Galasso" <agalasso at gndci.cs.cnr.it> 04/14/03 10:15AM
Steve,
I get again the same error with another kind of query: ITEMQUERYMAP
(and the previus problem is still not resolved :-(  )
http://laplace/mapserver/mapserv.exe
?map=calabria.map
&imgext=2664765.49+4367764.90+2718339.51+4340946.86
&imgsize=863+432
&qlayer=myLayer
&map_myLayer_filter=BLABLABLA
&mode=itemquerymap
&map_querymap_color=50+150+0
i receive an image with the original map-file extent.
I've tryed with: IMGEXT, MAPEXT, MAP_EXTENT but nothing! Seems like
they are
ignored by mapserver.
How can i do to obtain the correct image??
Regards,
Alessandro Galasso
----- Original Message -----
To: "steve.lime" <steve.lime at dnr.state.mn.us>
Sent: Monday, April 07, 2003 10:50 AM
Subject: Re: Real coordinates query
Any news about the problem?
Did you fix it in the next release?
Regards,
Alessandro Galasso
Hmmmm... What does the whole URL look like now? The map_extent=
influences the map file after all other parameter processing is done.
In
effect it *should* just be changing the default extent you set in the
map file. That's why it seemed a reasonable work around. What version
of
MapServer?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "emailfittizio at libero.it" <emailfittizio at libero.it> 04/01/03 01:58
AM >>>
Steve,
with &map_extent= the query run without error but the returned image
has
wrong extent (all image is visible not the specified zone).
Does the parameters order influence something?
Let me know.
Regards,
Alessandro.
There looks to be an error in the code. What happens is that setting
mapext also sets a query mode flag to use the extent for a query.
Futher
down in the code setting mapxy has no effect because there's a check
to
see if the query mode flag has already been set, and if so don't
override it. The easiest work around is to use an alternative method
to
set the map extent. I think that if you use "&map_extent=" instead of
"&mapext=" it should work. Give that a shot and let me know how it
goes.
I'll file this as a bug otherwise and will try to fix for 3.7.
Steve
Stephen Lime
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "emailfittizio at libero.it" <emailfittizio at libero.it> 03/31/03
01:41AM >>>
Hi Steve. I'm sorry to boring you with this question, but... it
doesn't
go:
http://laplace/mapserver/mapserv.exe?
map=calabria/calabria.map
&mapext=2611685.07+4392492.28+2903099.95+4286980.00
&mapsize=1024+370
&layers=limiti_comunali
&mapxy=2646326.95+4362345.91
&mode=querymap
The error is:
mapserv(): Web application error. Query mode needs a point, imgxy and
mapxy are not set.
If i remove "mapext" the query run fine. But, of course, return me the
entire map...
Where is the problem?
Thanks a lot,
Alessandro.
Hi Alessandro: It's certainly possible to use real coordinates. Just
remove the imgext, imgsize and img.x/y parameters and add a mapxy
parameter that holds the coordinate of interest and that should do it.
Steve
Stephen Lime
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "emailfittizio at libero.it" <emailfittizio at libero.it> 03/25/03
04:18AM >>>
Hi list,
At the moment i use this line to query the CGI:
http://laplace/mapserver/mapserv.exe?map=calabria/calabria.map&imgext=257484
7.224432619+4449795.614692735+3352308.224432619+4195815.614692735&imgsize=10
24+334&layers=bacini&img.x=74.33&img.y=111.50&mode=querymap
Is it possible to query the server with the world coordinate insteed
of
using img.x img.y ?
If it'possible.. How the query string will change?
Thanks,
Alessandro.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
