[Mapserver-users] mapserver is generating a blank
image.....please help
Sreekanth S Rameshaiah
sree at mahiti.org
Tue Apr 22 06:04:53 EDT 2003
I solved it. I had to use a utility challed sahpechk.exe. I found out
that the shape type definition for the file I was using was polygonZ. I
got the shape file recreated with polygon type info. Now things are
working fine.
However now I want the map file to pick the value from query string,
which is not happening. Any Ideas?
I have a a value called VILLAGECode from the previous page submission.
i want to use it in place of 54 in the below code
# CLASSITEM "CLASS"
CLASS # States class
NAME "VILLAGE"
EXPRESSION ([LOC_CODE] = 54 ) ### This needs to be replaced by form
element VILLAGECode value
COLOR 240 0 240
OUTLINECOLOR 50 55 0
END # end of States class object
Regards,
- sree
On Tue, 2003-04-22 at 08:54, Sarawut Ninsawat wrote:
> I think your problem should be about projection or extent of display map if
> you just add your shp file to demo.map
> I hope that help you
> Sarawut
> At 12:42 PM 4/21/2003 +0530, you wrote:
> >Dear friends,
> >Have installed mapserver over the weekend on my linux system. The demo
> >files and the tutorial shp files are working correctly and images are
> >getting generated. However when I use my town shape files mapserver
> >generates a blank image.
> >I do not know how to debug/ interpret this. Please help.
> >My town shape file can be downloaded from
> >http://216.17.167.83/shp_files/shape.zip
> >Basically this map file has only one layer and contains demarketed
> >areas. I would like to select areas based on id such as id <=10.
> >Thanks in advance.
> > - sree
_________________________________
CTO
Mahiti Infotech Pvt. Ltd.
Bangalore - 560071
India
Ph: +9180 51150 580/1/2/3
Visit www.mahiti.org
