[Mapserver-users] jpeg output
Howard Mark MHoward at spaceimaging.com
Wed Apr 23 12:05:21 EDT 2003
I had this issue when the projection info for the image did not match the
map file projection.
Check that your JPW file coordinates match and that the EPSG code for the
map is for the same projection.
Hope this helps,
Mark
-----Original Message-----
From: Christina Biakowski (CCGIS) [mailto:christina.biakowski at ccgis.de]
Sent: Wednesday, April 23, 2003 9:47 AM
To: Howard Mark; Mapserver-Users at Lists. Gis. Umn. Edu
Subject: AW: [Mapserver-users] jpeg output
I think the description of my problem was not quite precise. I don't get any
error message; actually Mapserver renders an jpg-image, which is saved under
the defined IMAGEPATH but it's empty.
Christina
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Howard
Mark
Gesendet: Mittwoch, 23. April 2003 16:57
An: 'Christina Biakowski (CCGIS)'; Mapserver-Users at Lists. Gis. Umn. Edu
Betreff: RE: [Mapserver-users] jpeg output
Christina,
Are you getting the JPEG library version error?
The current windows binaries have a problem with the JPEG library versions.
I am looking for windows binaries that work with JPEG, GDAL and OGR. The WMS
connector doesn't work with this version because of the JPEG problem - even
if you're not using JPEG input! I'd like to be able to hook up to an OGC/WMS
data source and also SDE.
I want to be able to demonstrate our imagery data sets using Mapserver, I
just don't have time to debug this problem.
Hopefully, someone can help both of us!
Mark
Sent: Wednesday, April 23, 2003 5:09 AM
To: Mapserver-Users at Lists. Gis. Umn. Edu
Subject: [Mapserver-users] jpeg output
Hello,
I have installed MapServer using the by dmsolutions provided
Windows-binaries version mapserver-3.6.4-win32-php4.3.0-libwww:
MapServer version 3.6.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Though JPEG is supported I can't render jpg-images as output. Using the
other formats everything works fine.
Do I have to install an additional library to render jpgs?
Thanks in advance!
Christina
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
