AW: [Mapserver-users] jpeg output
Howard Mark MHoward at spaceimaging.com
Wed Apr 23 13:05:57 EDT 2003
THANKS! THANKS! THANKS!
I now can connect to WMS :)
Can't do SDE though :(
Mark
-----Original Message-----
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Wednesday, April 23, 2003 10:00 AM
To: Howard Mark
Cc: Christina Biakowski (CCGIS); Mapserver-Users at Lists. Gis. Umn. Edu
Subject: Re: AW: [Mapserver-users] jpeg output
Hi There,
 There was some issues with conflicting jpeg libraries used in the build of
gd/mapserver/gdal. I have rebuild a new 3.6.6-dev version which load
properly a
jpeg file and save properly to a jpeg output. The new zip is at :
http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.6.6-dev-win32-php4.3.0-l
ibwww.zip
Later,
"Christina Biakowski (CCGIS)" wrote:
> I think the description of my problem was not quite precise. I don't get
any
> error message; actually Mapserver renders an jpg-image, which is saved
under
> the defined IMAGEPATH but it's empty.
> Christina
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Howard
> Mark
> Gesendet: Mittwoch, 23. April 2003 16:57
> An: 'Christina Biakowski (CCGIS)'; Mapserver-Users at Lists. Gis. Umn. Edu
> Betreff: RE: [Mapserver-users] jpeg output
> Christina,
> Are you getting the JPEG library version error?
> The current windows binaries have a problem with the JPEG library
versions.
> I am looking for windows binaries that work with JPEG, GDAL and OGR. The
WMS
> connector doesn't work with this version because of the JPEG problem -
even
> if you're not using JPEG input! I'd like to be able to hook up to an
OGC/WMS
> data source and also SDE.
> I want to be able to demonstrate our imagery data sets using Mapserver, I
> just don't have time to debug this problem.
> Hopefully, someone can help both of us!
> Mark
> From: Christina Biakowski (CCGIS) [mailto:christina.biakowski at ccgis.de]
> Sent: Wednesday, April 23, 2003 5:09 AM
> To: Mapserver-Users at Lists. Gis. Umn. Edu
> Subject: [Mapserver-users] jpeg output
> Hello,
> I have installed MapServer using the by dmsolutions provided
> Windows-binaries version mapserver-3.6.4-win32-php4.3.0-libwww:
> MapServer version 3.6.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Though JPEG is supported I can't render jpg-images as output. Using the
> other formats everything works fine.
> Do I have to install an additional library to render jpgs?
> Thanks in advance!
> Christina
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> This message is intended only for the use of the Addressee and may
> contain information that is PRIVILEGED and CONFIDENTIAL.
> If you are not the intended recipient, you are hereby notified that any
> dissemination of this communication is strictly prohibited. If you have
> received this communication in error, please erase all copies of the
> message and its attachments and notify Space Imaging immediately.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
