[Mapserver-users] Mapserver and POSTGIS and RASTER layer
Paul Ramsey
pramsey at refractions.net
Wed Apr 23 15:33:35 EDT 2003
Rosangela,
No, it's not possible with the current PostGIS and Mapserver. Your
description is a very good "use case" for how such a functionality might
be made to work. Would you like to fund the R&D to make it possible? If
others are also interested in this capability, a jointly funded
development project could share the expense of adding the new capability
to PostGIS and Mapserver.
Yours,
Paul
Rosangela Silva wrote:
> Hello,
> I'd like to use mapserver with posgis for manipulate raster data
> and I'd like to know if is possible to do this:
> - pass a variable to a MAP FILE (in execution time) into a SQL SELECT
> - mosaic some blobs resultant of an SQL SELECT
> Something like this:
> LAYER #Raster
> CONNECTIONTYPE postgis
> NAME "sp_images"
> CONNECTION "user=postgresql password="" dbname=gisdb host=localhost"
> =>>> DATA " SELECT data from sp_image where sp_image.the_geom && EXTEND "
> STATUS DEFAULT
> TYPE RASTER
> OFFSITE 0
> END
> data is of blob type and the select probably result a number of
> blobs registers. I'd like to mosaic this blobs and form an raster layer
> on execution time. The EXTEND is a variable passed in execution time
> with MapServer extend box request.
> Is it possible??
> Thanks in advance,
> Rosangela.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
