[Mapserver-users] QueryByPoint on PostGIS layer
steff stephane.riff at cerene.fr
Thu Apr 24 05:24:08 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0011_01C30A54.057944B0
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi all.
=20
My problem is :
=20
  I've got a postgis layer
=20
LAYER
  CONNECTIONTYPE postgis
  NAME "Contour_Departements"
  CONNECTION "dbname=3Ddb port=3D5555 user=3Dapache"
  DATA "the_geom from giscontourdepartement"
  TYPE POLYGON
  STATUS OFF
  GROUP "Contour"
#  FILTER "shapdpt_id LIKE '%value%%'"
  HEADER blank.html
  FOOTER blank.html
  CLASS
    NAME "Contour_Departements1"
    EXPRESSION ([dept_id] =3D 0)
    SYMBOL "star"
    SIZE 8
    OUTLINECOLOR 255 0 0
    COLOR 255 0 255
    OVERLAYSYMBOL "downwarddiagonalfill"
    OVERLAYSIZE 6
    OVERLAYCOLOR 0 0 0
    TEMPLATE "itemquery_template.html"
  END
  CLASS
    NAME "Contour_Departements2"
    EXPRESSION ([dept_id] =3D 1)
    SYMBOL "cross"
    SIZE 8
    COLOR 255 128 64
  END
=20
  METADATA
   LYRNAME "Contour de D=E9partements"
   TABLE_NAME "giscontourdepartement"
   RESULT_FIELDS "area"
   WMS_SRS  "EPSG:27582"
   WMS_ORDER "2"
  END
=20
END
=20
=20
I want to query this layer with :
=20
    $nClickGeoX =3D pix2Geo($_SESSION["map_x"], 0, $map->width,$dfMinX, =
$dfMaxX,=20
0);
    $nClickGeoY =3D pix2Geo($_SESSION["map_y"], 0, $map->height,$dfMinY, =
$dfMaxY,=20
1);
    $oClickGeo =3D ms_newPointObj();
    $oClickGeo->setXY($nClickGeoX, $nClickGeoY);
    $err =3D @$map->queryByPoint($oClickGeo, MS_SINGLE, -1);
    if($err =3D=3D MS_SUCCESS)
      $queryResults=3DTRUE;
      dumpQueryResults () ;
      print( "<script =
language=3D\"javascript\">parent.queryResult.window.location=20
=3D\"legend/queryResult.php\";</script>" );
=20
=20
function dumpQueryResults()
    GLOBAL $map;
    $numResultsTotal =3D 0;
    $fp =3D fopen("legend/queryResult.php", "w+");
    for($iLayer=3D0; $iLayer < $map->numlayers; $iLayer++)
        $oLayer =3D $map->GetLayer($iLayer);
        $numResults =3D $oLayer->getNumResults();
        if ($numResults =3D=3D 0)
            continue;  // No results in this layer
        // Open layer's table... take the list of fields to display from =
        // the "HEADERRESULT_FIELDS" metadata in the layer object.
        //$oLayer->open($map->shapepath);
        $oLayer->open("");
        $selFields =3D explode(" ", =
$oLayer->getMetaData("RESULT_FIELDS"));    =20
        fwrite($fp,"<html>\n<body bgcolor=3D\"#ADCEED\">\n<TABLE =
BORDER=3D0=20
CELLSPACING=3D1 CELLPADDING=3D2
WIDTH=3D100%%>\n");
        fwrite($fp,"<TR>\n");
        fwrite($fp,"<TD COLSPAN=3D".sizeof($selFields)." =
BGCOLOR=3D#C1D8E3>");
        fwrite($fp,"<CENTER> ".$oLayer->getMetaData("LYRNAME")." =
</CENTER>" );
        fwrite($fp,"</TR>\n");=20
        // Table header: attribute names...
        fwrite($fp,"<TR>\n");=20
        for ($iField=3D0; $iField < sizeof($selFields); $iField++)
            fwrite($fp,"<TD BGCOLOR=3D#E2EFF5>");
            fwrite($fp,"".$selFields[$iField]."");
            fwrite($fp,"</TD>");
        // One row in table for each selected record
        for ($iRes=3D0; $iRes < $numResults; $iRes++)
            $oRes =3D $oLayer->getResult($iRes);
            if($oRes !=3D FALSE)
              $oShape =3D $oLayer->getShape(-1,$oRes->shapeindex);
              //fwrite($fp,"<!--
bounds(".$oShape->bounds->minx.",".$oShape->bounds->miny.")-
(".$oShape->bounds->maxx.",."$oShape->bounds->maxy.")-->\n"
              for($iField=3D0; $iField < sizeof($selFields); $iField++)
                fwrite($fp,"<TD BGCOLOR=3D#FFFFFF>");
                fwrite($fp,"".$oShape->values[$selFields[$iField]]."");
              $oShape->free();
              $numResultsTotal++;
        $oLayer->close();
        fwrite($fp,"</TABLE>\n</body>\n</html>\n");
    if ($numResultsTotal =3D=3D 0)
        fwrite($fp,"Nothing found at query location.");
  fclose($fp);
=20
=20
But i get always the same error :
   Fatal error: Assertion failed, Could not set shape values: 0, 0
=20
I already look in the users-list but there is no answer...
The only answer is to use  layer->open(""); but i already do this =
without=20
result....
I received a mail from Daniel Morissette who told me he think it's a bug =
with shape creation from postgis without attribute so numvalue and =
numitem are set to 0.
but my table structure is :
 OID | GID | DEPT_ID | AREA | THE_GEOM |
=20
 So why numvalue is set to 0 i don't know...
-> i get this work few month ago with mapserver 3.6.4 and postgres 7.2 =
now i'm using mapserver 3.6.5 and postgres 7.3
If someone could help me.  :)
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial>Hi all.<BR> <BR>My problem is :<BR> <BR>&nbsp; =
I've got a=20
postgis layer<BR> <BR>LAYER<BR>&nbsp; CONNECTIONTYPE postgis<BR>&nbsp; =
NAME=20
"Contour_Departements"<BR>&nbsp; CONNECTION "dbname=3Ddb port=3D5555=20
user=3Dapache"<BR>&nbsp; DATA "the_geom from =
giscontourdepartement"<BR>&nbsp; TYPE=20
POLYGON<BR>&nbsp; STATUS OFF<BR>&nbsp; GROUP "Contour"<BR>#&nbsp; FILTER =
"shapdpt_id LIKE '%value%%'"<BR>&nbsp; HEADER blank.html<BR>&nbsp; =
FOOTER=20
blank.html<BR>&nbsp; CLASS<BR>&nbsp;&nbsp;&nbsp; NAME=20
"Contour_Departements1"<BR>&nbsp;&nbsp;&nbsp; EXPRESSION ([dept_id] =3D=20
0)<BR>&nbsp;&nbsp;&nbsp; SYMBOL "star"<BR>&nbsp;&nbsp;&nbsp; SIZE=20
8<BR>&nbsp;&nbsp;&nbsp; OUTLINECOLOR 255 0 0<BR>&nbsp;&nbsp;&nbsp; COLOR =
255 0=20
255<BR>&nbsp;&nbsp;&nbsp; OVERLAYSYMBOL=20
"downwarddiagonalfill"<BR>&nbsp;&nbsp;&nbsp; OVERLAYSIZE =
6<BR>&nbsp;&nbsp;&nbsp;=20
OVERLAYCOLOR 0 0 0<BR>&nbsp;&nbsp;&nbsp; TEMPLATE=20
"itemquery_template.html"<BR>&nbsp; END<BR>&nbsp; =
CLASS<BR>&nbsp;&nbsp;&nbsp;=20
NAME "Contour_Departements2"<BR>&nbsp;&nbsp;&nbsp; EXPRESSION ([dept_id] =
=3D=20
1)<BR>&nbsp;&nbsp;&nbsp; SYMBOL "cross"<BR>&nbsp;&nbsp;&nbsp; SIZE=20
255 128=20
64<BR>&nbsp;&nbsp;&nbsp; TEMPLATE "itemquery_template.html"<BR>&nbsp; =
END<BR>=20
<BR>&nbsp; METADATA<BR>&nbsp;&nbsp; LYRNAME "Contour de=20
D=E9partements"<BR>&nbsp;&nbsp; TABLE_NAME =
"giscontourdepartement"<BR>&nbsp;&nbsp;=20
RESULT_FIELDS "area"<BR>&nbsp;&nbsp; WMS_SRS&nbsp; =
"EPSG:27582"<BR>&nbsp;&nbsp;=20
WMS_ORDER "2"<BR>&nbsp; END<BR> <BR>END<BR> <BR> <BR>I want to query =
this layer=20
with :<BR> <BR>&nbsp;&nbsp;&nbsp; $nClickGeoX =3D =
pix2Geo($_SESSION["map_x"], 0,=20
$map-&gt;width,$dfMinX, $dfMaxX, <BR>0);<BR>&nbsp;&nbsp;&nbsp; =
$nClickGeoY =3D=20
pix2Geo($_SESSION["map_y"], 0, $map-&gt;height,$dfMinY, $dfMaxY,=20
<BR>1);<BR>&nbsp;&nbsp;&nbsp; $oClickGeo =3D=20
ms_newPointObj();<BR>&nbsp;&nbsp;&nbsp; =
$oClickGeo-&gt;setXY($nClickGeoX,=20
$nClickGeoY);<BR>&nbsp;&nbsp;&nbsp; $err =3D =
@$map-&gt;queryByPoint($oClickGeo,=20
MS_SINGLE, -1);<BR>&nbsp;&nbsp;&nbsp; if($err =3D=3D=20
MS_SUCCESS)<BR>&nbsp;&nbsp;&nbsp; {<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
$queryResults=3DTRUE;<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; dumpQueryResults =
()=20
;<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; print( "&lt;script=20
language=3D\"javascript\"&gt;parent.queryResult.window.location=20
<BR>=3D\"legend/queryResult.php\";&lt;/script&gt;" =
);<BR>&nbsp;&nbsp;&nbsp; }<BR>=20
<BR> <BR>function dumpQueryResults()<BR>{<BR>&nbsp;&nbsp;&nbsp; GLOBAL=20
$map;<BR>&nbsp;&nbsp;&nbsp; $numResultsTotal =3D =
0;<BR>&nbsp;&nbsp;&nbsp; $fp =3D=20
fopen("legend/queryResult.php", "w+");<BR>&nbsp;&nbsp;&nbsp; =
for($iLayer=3D0;=20
$iLayer &lt; $map-&gt;numlayers; $iLayer++)<BR>&nbsp;&nbsp;&nbsp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; $oLayer =3D=20
$map-&gt;GetLayer($iLayer);<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=
=20
$numResults =3D=20
$oLayer-&gt;getNumResults();<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
; if=20
($numResults =3D=3D=20
0)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
continue;&nbsp; // No results in this=20
layer<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Open layer's =
table...=20
take the list of fields to display from=20
<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // the =
"HEADERRESULT_FIELDS"=20
metadata in the layer =
object.<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
//$oLayer-&gt;open($map-&gt;shapepath);<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=
&nbsp;&nbsp;=20
$oLayer-&gt;open("");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
$selFields =3D=20
explode(" ", =
$oLayer-&gt;getMetaData("RESULT_FIELDS"));&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;html&gt;\n&lt;body bgcolor=3D\"#ADCEED\"&gt;\n&lt;TABLE =
BORDER=3D0=20
<BR>CELLSPACING=3D1=20
CELLPADDING=3D2<BR>WIDTH=3D100%%&gt;\n");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
p;&nbsp;&nbsp;=20
fwrite($fp,"&lt;TR&gt;\n");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=
=20
fwrite($fp,"&lt;TD COLSPAN=3D".sizeof($selFields)."=20
BGCOLOR=3D#C1D8E3&gt;");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;CENTER&gt; ".$oLayer-&gt;getMetaData("LYRNAME")."=20
&lt;/CENTER&gt;" );<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;/TR&gt;\n"); =
//<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Table header: =
attribute=20
names...<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
//<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
fwrite($fp,"&lt;TR&gt;\n");=20
<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for ($iField=3D0; $iField =
&lt;=20
sizeof($selFields); =
$iField++)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;TD=20
BGCOLOR=3D#E2EFF5&gt;");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb=
fwrite($fp,"".$selFields[$iField]."");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&=
fwrite($fp,"&lt;/TD&gt;");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
}<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;/TR&gt;\n");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
;=20
//<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // One row in table for =
each=20
selected record<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
//<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; for ($iRes=3D0; $iRes =
&lt;=20
$numResults; $iRes++)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; =
$oRes =3D=20
$oLayer-&gt;getResult($iRes);<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
if($oRes !=3D=20
FALSE)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb=
sp;=20
{<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;=20
$oShape =3D=20
$oLayer-&gt;getShape(-1,$oRes-&gt;shapeindex);<BR>&nbsp;&nbsp;&nbsp;&nbsp=
//fwrite($fp,"&lt;!--<BR>bounds(".$oShape-&gt;bounds-&gt;minx.",".$oShape=
-&gt;bounds-&gt;miny.")-<BR>(".$oShape-&gt;bounds-&gt;maxx.",."$oShape-&g=
t;bounds-&gt;maxy.")--&gt;\n"<BR>);<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs=
for($iField=3D0; $iField &lt; sizeof($selFields);=20
$iField++)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
BGCOLOR=3D#FFFFFF&gt;");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb=
fwrite($fp,"".$oShape-&gt;values[$selFields[$iField]]."");<BR>&nbsp;&nbsp=
;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=
&nbsp;=20
fwrite($fp,"&lt;/TD&gt;");<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&=
}<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;=20
$oShape-&gt;free();<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
$numResultsTotal++;<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n=
bsp;&nbsp;=20
$oLayer-&gt;close();<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
fwrite($fp,"&lt;/TABLE&gt;\n&lt;/body&gt;\n&lt;/html&gt;\n");<BR>&nbsp;&n=
bsp;&nbsp;=20
}<BR>&nbsp;&nbsp;&nbsp; if ($numResultsTotal =3D=3D=20
0)<BR>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; fwrite($fp,"Nothing =
found at=20
query location.");<BR>&nbsp; fclose($fp);<BR>}<BR> <BR> <BR>But i get =
always the=20
same error :<BR>&nbsp;&nbsp; Fatal error: Assertion failed, Could not =
set shape=20
values: 0, 0<BR> <BR>I already look in the users-list but there is no=20
answer...<BR>The only answer is to use&nbsp; layer-&gt;open(""); but i =
already=20
do this without <BR>result....<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I received a mail from <FONT =
face=3D"Times New Roman"=20
size=3D3>Daniel Morissette who told me he think it's a bug with shape =
creation=20
from postgis without attribute so numvalue and numitem are set to=20
0.</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman" =
size=3D3>but my table=20
structure is :</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3DArial =
size=3D2></FONT></FONT>&nbsp;</DIV>
size=3D3>&nbsp;OID | GID=20
| DEPT_ID | AREA | THE_GEOM |<BR>&nbsp;<BR> So why numvalue is set to 0 =
i don't=20
know...</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman"=20
size=3D3></FONT></FONT>&nbsp;</DIV>
size=3D3>-&gt; i get=20
this work few month ago with mapserver 3.6.4 and postgres 7.2 now i'm =
using=20
mapserver 3.6.5 and postgres 7.3</FONT></FONT></DIV>
<DIV>&nbsp;</DIV>
size=3D3>If someone=20
could help me.&nbsp; :)</FONT></FONT></DIV>
size=3D3></FONT>&nbsp;</DIV></FONT></BODY></HTML>
------=_NextPart_000_0011_01C30A54.057944B0--
