[Mapserver-users] Supported GML-Version OGR/MapServer
Thu Apr 24 09:20:46 EDT 2003
Christina Biakowski (CCGIS) wrote:
> Hello,
> which GML Version is supported by Mapserver/OGR?
> I have converted Shapefiles to GML using the OGR Utilities
> org2ogr-Tool(http://gdal.velocet.ca/projects/opengis/ogrhtml/ogr_utilities.h
> tml) and successfully integrated in my MapServer-Application (Version
> 3.6.4).
> To integrate GIS-Data in my MapServerApplication, that is not supported by
> OGR, I have converted it to a GML-File compliant to the GML 3 specification
> (I hope I have implemented the specifictions correctly...), but it didn't
> work with MapServer.
> Having a closer look at the by ogr2ogr generated GML-File I have noticed
> that it contains GML-Tags that are deprecated in GML 3.0 (e.g.
> gml:innerBounderyIs).
Christina,
OGR is based on GML 2.0 and there are even lots of GML 2 files that might
defeat it.  Basically if the ogrinfo utility works with a GML file then
mapserver should.
If you send me the GML file causing problems I might be able to work out
what is wrong.
Best regards,
