[Mapserver-users] Problem with ECW
Fri Apr 25 09:42:02 EDT 2003
Braulio M. S. wrote:
> Hi list,
> I am using archives ecw and I have a problem. When I do Zoom In in the image arrives a little in which the image becomes black. Which could be the problem?
This problem was fixed in the GDAL ECW driver on October 1st, 2002.  If
you are using the 1.1.8 release of GDAL or later you should have this fix.
If you built from source you can check gdal/frmts/ecw/ecwdataset.cpp to
ensure it includes revision 1.10.
Best regards,
