[Mapserver-users] which ./configure options needed?
Benjamin Thelen benjamin.thelen at ccgis.de
Fri Apr 25 11:01:26 EDT 2003
Hi again,
I could find out with which options php was compiled:
./configure' '--with-apxs=/usr/local/sbin/apxs'
'--with-config-file-path=/usr/local/etc' '--enable-versioning'
'--with-regex=system' '--without-gd' '--without-mysql'
'--with-gd=/usr/local' '--enable-gd-native-ttf'
'--with-freetype-dir=/usr/local' '--with-jpeg-dir=/usr/local'
'--with-png-dir=/usr/local' '--with-zlib' '--with-pdflib=/usr/local'
'--with-zlib-dir=/usr' '--with-jpeg-dir=/usr/local'
'--with-png-dir=/usr/local' '--with-tiff-dir=/usr/local'
'--with-mysql=/usr/local' '--with-pgsql=/usr/local' '--with-dbase'
'--with-expat-dir=/usr/local' '--with-dom=/usr/local' '--prefix=/usr/local'
'i386-portbld-freebsd4.7'
So, as you can see, it was compiled with regex=system.
What can I do now??
Ben
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
> Jean-Francois.Doyon at CCRS.NRCan.gc.ca
> Sent: Tuesday, April 22, 2003 9:40 PM
> To: benjamin.thelen at ccgis.de; mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] which ./configure options needed?
> Benjamin,
> Well, the configure does attempt to detect many libraries, namely GD,
> assuming you want to use the system's GD.
> The options you listed will give you a WMS Client capable MapServer, along
> with many other features (Reprojection, improved raster support, etc ...).
> If in doubt as to the path to the libraries, on linux, you would build the
> code, and install the libraries onto the system.  Normally, if you install
> the libraries (such as OGR/GDAL) onto the system a simple --with-ogr and
> --with-gdal will work, no need to feed it a path, configure will find what
> it needs.
> Basically, if you "make install" all the libs, you should be good
> to go with
> no paths to specify to mapserver. I haven't played with FreeBSD in years,
> but I suspect the same rules apply?
> This only gets more complicated if you DON'T want to install the libraries
> system wide, and then have to worry about include,lib, and ld
> paths ... But
> that's another story :)
> In your example, you've got it right ... you could actually NOT put any
> paths anywhere except for PHP maybe, and that should still work
> fine (looks
> like you did a system install of the software and libs).  Yes, normally
> libjpeg and zlib are detected automagically, as is libfreetype (though you
> may have to play with this depending on the version of freetype
> you have, or
> if you have both).
> Give that a try. If you have problems, post the output of the configure
> script and maybe we can help.
> J.F.
> From: Benjamin Thelen [mailto:benjamin.thelen at ccgis.de]
> Sent: Tuesday, April 22, 2003 3:14 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] which ./configure options needed?
> Hello,
> I would like to use mapserver with postgis 0.4.7 on FreeBSD 4.7. I have
> installed the neccessary Software:
> GD2 (from FreeBSD Ports-Collection)
> PROJ4 (	"	)
> LibWWW (	"	)
> FreeType Version 2 (	"	)
> GDAL 1.1.8 (	"	)
> pgsql 7.3.2 (	"	)
> postgis 0.7.4 (from tar.gz)
> What I couldn't install seperately was OGR, but as I could read on
> http://gdal.velocet.ca/projects/opengis/ that OGR is part of the GDAL
> library, I think that's it.
> I would like to start compiling, but I am quite unsure what
> options for the
> configure-skript I have to take, because it is written in the mapserver
> documentation that "Some libraries will NEVER be detected by default, and
> HAVE to be specified via the configure script". That would mean
> to me that I
> only have to take those options
> --with-proj, --with-ogr, --with-gdal, --with-wmsclient (I don't
> need mpatrol
> and sde), which are never detected and the rest will be detected
> automatically. But somehow I think, I am wrong ;-)!
> If ogr is part of gdal, why do I have to specify ogr seperately? I don't
> know how to specify the correct path to the installed software because,
> there are so many libraries installed with the software. If I had
> a specific
> file I would have to specify, no problem, but application path...?
> Do I have to specify the following two?
>  --with-postgis	(automatically detected?)
>  --with-php		(automatically detected?)
> I would try the following:
> ./configure
>  --with-gd=/usr/local/share/locale/l10n	(not sure)
>  --with-proj=/usr/local/bin/			(quite sure)
>  --with-ogr= ?? 					(see above !!)
>  --with-gdal=/usr/local/bin/gdal-config 	(sure)
>  --with-php=/usr/local/bin/php		(sure)
>  --with-wmsclient					(sure)
>  --enable-runpath	(sure, but what about the additional options)
>  --with-postgis=/usr/local/bin/pg_config	(sure)
> I am definitely not sure, whether to specify the following:
>  --with-jpeg[=DIR]	(not neccessary because auf GD2?)
>  --with-zlib		(automatically detected?)
>  --with-freetype		(automatically detected?)
> Can anybody help?
> Thanks very much!
> Benjamin
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
